Spec of the car for anyone who's interested! Probably missed some bits!
Engine
Forged 4EFTE – Built by Rob Barnard @ PEC Automotive
74.5mm Wossner Pistons
Scat Rods
ARP Rod Bolts
ARP Head Bolts
Athena 1.2mm Head Gasket
OEM Full Gasket Kit
OEM Water Pump
OEM Oil Pump
NGK Iridium Spark Plugs
Sard Fuel Pressure Regulator
550cc Denso Injectors (flow tested)
Zisco Oil Catch Tank
Gloss Black Race Spec Cam Cover
Magnacore Leads
Clear Cambelt cover
Turbo/Exhaust
WEPR M/S Top Mount Manifold
WEPR Stainless Downpipe
WEPR Stainless Screamer pipe
WEPR Stainless Turbo Oil Return pipe
Blitz Nur Spec Exhaust System (Bottleneck Removed by Solid Fabrications)
Greddy T518Z Turbo (upgraded to billet comp wheel)
Turbosmart 38mm External Wastegate
Drive chain
Standard Gearbox
Cusco LSD
SPEC 6 Clutch
KPH to MPH converter (removes 180mph limit)
Cooling
JPerformance Intercooler (Modified for rear entry)
JPerformance Boost Pipes
ID Workz Triple Core Radiator & Slim line Fan
Electronics
Greddy E-Manage Ultimate & 3bar Map Sensor
Greddy E-01 Boost Controller
Greddy Manual Boost Gauge
AEM Wideband
Innovate Oil Pressure/Temp Gauge
HKS turbo timer
Interior
Corbeau Club Sport Seats
Bride Seat Rails
Drivers Sabelt 4 Point Harness
Rear Cusco Carbon Strut Brace
Short Shifter
Cruise Gear Knob
Exterior
15” Rota GT3’s
Avon CR500 Semi Slick Tyres
20mm Front Hub centric Spacers
Optional Extra Wind Deflectors
Optional Extra Window Tints
Braking/Suspension
Meister R Coilovers
Toyota Levin Front Calipers
EBC yellow stuff front pads
EBC red stuff rear pads
Drilled & grooved rear discs (recently replaced)
HEL Brake Lines
HEL ABS Removal Kit
Polybush Engine/Gearbox Mounts
Mapping/Tuning
Mapped @ Tuning Developments – 295.4BHP @ 1.4BAR
  • Replies 463
  • Created
  • Last Reply
Top Posters In This Topic
I said exactly the same Charlie, now 100% regret selling it
I will probably be the same buddy, but its time for a change
If my scobby sells il be on your doorstep haha best of luck with the sale :)
one hell of spec and hard work gone into this
James
Cheers bud, really appreciate it!
Quick update on the crank pulley, decided to get a lightweight pulley from Fensport after struggling to find a standard pulley in good condition! Fitted this last night and issue solved!
Posted Image
Posted Image
Sent from my iPhone using Tapatalk
Love this build. After everything that went on with the old engine etc it's good to see it coming along so well!
Thanks bud!
Was the old pully hard to get off? Do you feel any difference now- free revving?
It was very loose! Basically i wasn't using the correct pulley to start with but my engine builder had machined it to fit and somehow it had come loose! I've not noticed anything different with this lightweight pulley fitted bud.
  • 3 weeks later...
