Ollieh17 Posted October 20, 2014 Share Posted October 20, 2014 Just bought a lightened cusco flywheel and getting round to installing it soon. Is it a cause of just bolting on and alls good. Or does the engine have to be in a certain position, top dead centre etc? Been told is does but don't see the difference it would make Quote Link to post Share on other sites
Socks Posted October 20, 2014 Share Posted October 20, 2014 Engine doesn't need to be in any particular position.... as your not altering timing.... Just make sure you use NEW flywheel bolts and torque them to the correct settings. you DO NOT want that coming loose believe me! Quote Link to post Share on other sites
turbo Grant Posted October 20, 2014 Share Posted October 20, 2014 Just bolt it up Quote Link to post Share on other sites
Ollieh17 Posted October 20, 2014 Author Share Posted October 20, 2014 Thought as much Quote Link to post Share on other sites
5e colin Posted October 20, 2014 Share Posted October 20, 2014 i used loctite blue to secure my aasco Quote Link to post Share on other sites
Phil Posted October 20, 2014 Share Posted October 20, 2014 On 10/20/2014 at 10:27 AM, Socks said: Engine doesn't need to be in any particular position.... as your not altering timing....Just make sure you use NEW flywheel bolts and torque them to the correct settings. you DO NOT want that coming loose believe me!Are the stock bolts stretched under torque?I always thought it was only the headbolts that were perishable items?Only ask as I'll be fitting a lightened flywheel myself soon and as you mentioned it's the last thing you want to be out of balance or incorrectly fitted/fastenedPhil Quote Link to post Share on other sites
Socks Posted October 20, 2014 Share Posted October 20, 2014 For the sake of £3.... Its something id treat as very chuffing dangerous if it comes loose or out of balance like that... Hence why drag racers have to use those flywheel blankets... Quote Link to post Share on other sites
Phil Posted October 20, 2014 Share Posted October 20, 2014 (edited) Oh don't get me wrong I can see why you wouldn't want to get it wrong.But just never heard of using new bolts until you stuck it in capitals.Your at the sharp end of things their with racetech, do they recommend new flywheel bolts or have they had flywheel issues?Like you say for the sake of 3quid, wouldn't be taking a chance if folk have had issuesPhil Edited October 21, 2014 by Phil Quote Link to post Share on other sites
daniel_g Posted October 20, 2014 Share Posted October 20, 2014 New flywheel bolts should come with loctite on them, and i just put a wee bit extra on just to make sure lol. Quote Link to post Share on other sites
