Jay2ohh Posted October 27, 2014 Share Posted October 27, 2014 Fitted front mount today took it for a test drive straight after and it was boosting perfect, put bumper back on had my tea etc got back in driving fine was boosting but as soon as it got to 3.5-4k revs basically full boost it just stops boosting I lose the green lights and it's just driving without boost, is this fuel cut? It's not a bang that's it no boost it just stops, standard ecu meshed turbo front mount was set at .6 bar when everything was standardWhat can it be? Quote Link to post Share on other sites
_shaun_ Posted October 27, 2014 Share Posted October 27, 2014 are the revs holding back any at all?if so likely fuel cut from boost spiking in the cold. If not likely a boost leak somewhere. Quote Link to post Share on other sites
Matt1878 Posted October 27, 2014 Share Posted October 27, 2014 Do you have a boost gauge?.. Is it holding boost at 0.6 bar? Quote Link to post Share on other sites
Gainzy Posted October 27, 2014 Share Posted October 27, 2014 Sounds like a boost leak check pipe's definitely buy a decent boost gauge if you havn't already Quote Link to post Share on other sites
mikey4410 Posted October 27, 2014 Share Posted October 27, 2014 Don't think thats a boost leak dude.sounds like fuel cut.what boost u getting to mate ?It should boost to 0.75 without issue.fuel cuts like "hitting a wall"Are you getting all 3 booat lights at all ? Quote Link to post Share on other sites
Matt1878 Posted October 27, 2014 Share Posted October 27, 2014 On 10/27/2014 at 10:07 PM, mikey4410 said: Don't think thats a boost leak dude.sounds like fuel cut.what boost u getting to mate ?It should boost to 0.75 without issue.fuel cuts like "hitting a wall"Are you getting all 3 booat lights at all ?I used to run 0.8 bar on the stock ECU with no problems.. I'm sure it's 0.85 bar that fuel cut comes in Quote Link to post Share on other sites
Jay2ohh Posted October 28, 2014 Author Share Posted October 28, 2014 its boosting around .7 now and the car will still drive and rev as normal but even free revving just on idle it cuts the boost out, its like it reaches full boost at 3.5-4k as normal then just powers itself back down and the lights go off one by one but still drives, theres no leaks at all, no weird noises picks up absolutely fine till that point Quote Link to post Share on other sites
Ethanep82 Posted October 28, 2014 Share Posted October 28, 2014 Sorry this is off topic, but what are these lights your talking about? Quote Link to post Share on other sites
sa15cr Posted October 28, 2014 Share Posted October 28, 2014 He's on about the 3 green lights in the centre of the rev counter that light up when you reach so much boost Quote Link to post Share on other sites
Jay2ohh Posted October 28, 2014 Author Share Posted October 28, 2014 Yeah the 3 boost lights in rev counter, it's worse now driving back home and I've got no boost at all -.- I think I'm going to have to take the front mount off :/ least I know how to put it together, Definately isn't fuel cut so something's not running right somewhere Quote Link to post Share on other sites
Jay2ohh Posted October 29, 2014 Author Share Posted October 29, 2014 ive come to the conclusion it is fuel cut but without the harshness, if i give it some it stops boosting at 4k and wont pick up anymore speed it just stays there BUT if i feather the throttle i can get it past 4k revs still building boost with 2 lights and can hear it spooling soon as i plant my foot it doesnt like it and stops the boost again so im going by that for now Quote Link to post Share on other sites
Ethanep82 Posted October 29, 2014 Share Posted October 29, 2014 On 10/28/2014 at 3:41 PM, sa15cr said: He's on about the 3 green lights in the centre of the rev counter that light up when you reach so much boostI'll never seen that? Is that a EP91 thing? Quote Link to post Share on other sites
DavidAshton Posted October 29, 2014 Share Posted October 29, 2014 Do you have a boost gauge? What is that doing? Basing anything on those boost lights is not accurate. Quote Link to post Share on other sites
karl. Posted October 29, 2014 Share Posted October 29, 2014 Might sound silly but have you connected the pipe from the turbo feed back up to the waste gate? Quote Link to post Share on other sites
Gainzy Posted October 31, 2014 Share Posted October 31, 2014 As above a decent boost gauge is a must it can save your engine and alot of guess work Quote Link to post Share on other sites
mikey4410 Posted October 31, 2014 Share Posted October 31, 2014 A boost gauge is such a basic MUST on a turbo car.u NEED to be able to keep an eye on that.and in ure case help you to find out whats happening. Quote Link to post Share on other sites
Mcinnes Posted October 31, 2014 Share Posted October 31, 2014 Seems like the problem that I had with my ep82 would pull to about 2 maybe 3 revs then stopped on the spot and gave me fuck all before spending any money check all pipes for any cuts splits not fastened properly or not on at all. If it doesn't solve it then look at the other options it took me nearly two days to find mine as it was loads of pin holes on one of my pipes. Quote Link to post Share on other sites
Gainzy Posted October 31, 2014 Share Posted October 31, 2014 Think of the cooling system like blowing up a balloon the slightest bit hole will make pressure escape as above anything over 0.85 will fuel cut check the turbo/intercooler gasket also Quote Link to post Share on other sites
