Charlie28 Posted November 15, 2014 Posted November 15, 2014 Can anyone confirm if this is an LSD box. I don't seem to have the LSD housing if it is! It has an open diff in the gearbox but is the LSD housing external? Quote
mikey4410 Posted November 15, 2014 Posted November 15, 2014 very possibly a stocker mate.take a few pic close up of were driveshafts go in Quote
morgey Posted November 15, 2014 Posted November 15, 2014 Thats deffo missing something. Most likely the oem external lsd unless a 4wd transfer case would bolt up? Quote
Charlie28 Posted November 15, 2014 Author Posted November 15, 2014 Is there just a housing that bolts on (first pic) ? Quote
Charlie28 Posted November 15, 2014 Author Posted November 15, 2014 But what's missing off the side then? Quote
mikey4410 Posted November 15, 2014 Posted November 15, 2014 defo non lsd but yeah I see what u mean now morgey.dont seem right ?? Quote
morgey Posted November 15, 2014 Posted November 15, 2014 Naa its not a oem non lsd box that. Id say youve got a lsd box without the lsd lol Quote
daniel_g Posted November 15, 2014 Posted November 15, 2014 Looks like an OEM LSD box missing the extra bit. Quote
daniel_g Posted November 15, 2014 Posted November 15, 2014 unless a 4wd transfer case would bolt up?I wonder... looks like it would bolt up.Anyone got pics of an OEM LSD out the box ? Quote
Charlie28 Posted November 15, 2014 Author Posted November 15, 2014 I think it's an OEM LSD box but I don't have the LSD external casing. But would it still have a open diff inside? Confused as to how it works! Quote
Charlie28 Posted November 16, 2014 Author Posted November 16, 2014 Ok, so I managed to get the external LSD and bolt it up today! Rob had removed it so he could get the shafts out! So I went and picked up the LSD and shafts! Now I have 2 LSD gearbox's! An OEM one and a EP91 box with a Cusco LSD. What's better? Presume the Cusco? Quote
daniel_g Posted November 16, 2014 Posted November 16, 2014 Ok, so I managed to get the external LSD and bolt it up today! Rob had removed it so he could get the shafts out! So I went and picked up the LSD and shafts! Now I have 2 LSD gearbox's! An OEM one and a EP91 box with a Cusco LSD. What's better? Presume the Cusco?Good stuff !! Quote
fiddlersport Posted November 18, 2014 Posted November 18, 2014 (edited) you collecting gearboxes ? lol Edited November 18, 2014 by fiddlersport Quote
Charlie28 Posted November 26, 2014 Author Posted November 26, 2014 you collecting gearboxes ? lol Ha, don't go there! Quote
Charlie28 Posted November 26, 2014 Author Posted November 26, 2014 Cusco will smash it out the park mate. Yeah i'm using the Cusco buddy & selling the OEM box! Quote
fiddlersport Posted November 26, 2014 Posted November 26, 2014 first rule of thumb when buying a lsd box, look through the shafts and hopefully that bar wont be there if you catch my drift ! Quote
Charlie28 Posted November 26, 2014 Author Posted November 26, 2014 An OEM LSD gearbox has an open diff. Looking through the driveshafts holes proves nothing! As the diff is actually external in the casing that sticks out. Quote
daniel_g Posted November 26, 2014 Posted November 26, 2014 An OEM LSD gearbox has an open diff. Looking through the driveshafts holes proves nothing! As the diff is actually external in the casing that sticks out.Charlie do you have any other pics of the OEM box stripped ? Or any pics of the diff itself ? Cheers. Quote
Charlie28 Posted November 27, 2014 Author Posted November 27, 2014 An OEM LSD gearbox's internals are no different to a NON-LSD gearbox. The OEM LSD gearbox has an open diff exactly the same as a NON-LSD box. The only difference is the casing which bolts on the side of the box. This casing contains some cogs which must work in the same way as an aftermarket LSD. Maybe someone could explain further home this works? Gearbox without the external casing on. External casing Together Quote
daniel_g Posted November 27, 2014 Posted November 27, 2014 Cheers for the pics bud, its just im toying with the idea of trying to mod a LSD into my 4wd gearbox, well strip the diffs and see if they can be built up as one. Longshot but might aswell try.Anyway from those pics the OEM LSD isnt gonna work.Although i reckon a 4wd diff would fit in an OEM LSD box (with the side casing removed) and the transfer box would bolt to bell housing... No real gain in this apart from a better 1st gear. Quote
5e colin Posted November 27, 2014 Posted November 27, 2014 i have been thinking of swapping the gear set out of an oem lsd and sticking the d4d set in there theoreticly it should work have you eny pics of the diff/crownweel how many bolts it hass Quote
