A lot of people have had engine failures after getting there cover powder coated. If your getting it done you really want to drill off the baffle and have totaly cleaned behind to make sure its 100% free or any forgein objects
I had to drill off the baffle and there was loads of shot in there left from the shot blast! You have to have it welded back on mind, I wouldnt trust tapping out the holes and putting bolts on, can you imagine if one came loose
I was blasting mine though not powder coating but went down the road of loctite and what not.
have had it off since and still tight and tidy.
Phil
Colin, i drilled out the original rivets. Then drilled a hole and tapped a couple but due to the nature of the alloy is tapped crap and bolts were loose on the threads. Could have tried riveting but theres nothing for the rivet to pull up to, like when you rivet a plate for example, would only be held by the force of the rivet against the sides of the drilled hole.
just did a spot of weld in each hole
Taps we got at work are top notch, the bolts would hold and would do with a bit of locktite but i just didnt feel safe with bolts up there upside down with all that oil thats all. Would make me uneasy lol
Edited by Turbo Goose
