tango123 Posted December 19, 2014 Posted December 19, 2014 just put levin twin pots on my glanza, now no brakes at all. i did bleed the system. pedal goes straight to the floor. help guyss?? Quote
nikhilkamdar12 Posted December 19, 2014 Posted December 19, 2014 You bled it from the furthest away from the master cylinder then 3rd ect...? Quote
tango123 Posted December 20, 2014 Author Posted December 20, 2014 didnt bleed the rears bud oops. will the master cyclinder need bleeding now too? Quote
iamlegend Posted December 20, 2014 Posted December 20, 2014 If only doing the front then not... Quote
FMuscle Posted December 20, 2014 Posted December 20, 2014 Unless you ran out of fluid in the reservoir, you shouldn't have to bleed the rears. Quote
tango123 Posted December 20, 2014 Author Posted December 20, 2014 didnt let the fluid run low. just got no brakes now Quote
turbo Grant Posted December 20, 2014 Posted December 20, 2014 You need to do some more bleeding if pedals not hard Quote
tango123 Posted December 20, 2014 Author Posted December 20, 2014 bled it again. starting at rear an still nothing Quote
fiddlersport Posted December 20, 2014 Posted December 20, 2014 is there absolutely no braking at all or does the pedal hit the floor then you get braking ? Quote
tango123 Posted December 20, 2014 Author Posted December 20, 2014 i've tried gravity bleed. didnt work so got a friend to help. pedal goes straight to the floor an no brake pressure at all. method open bleed nipple push pedal down, hold pedal an close nipple. repeat that a few times. starting at nsr then osr. nsf an osf. cant push the pedal down an open the bleed nipple as normally would as pedal goes straight to the floor. Quote
FMuscle Posted December 20, 2014 Posted December 20, 2014 Reminds me... Is the nipple pointing up? I've heard a few peps installing the calipers on the wrong side with similar issues... Quote
tango123 Posted December 20, 2014 Author Posted December 20, 2014 they wouldnt fit the wrong way around would they? Quote
morgey Posted December 20, 2014 Posted December 20, 2014 Yes they probably would as the stock ones do. Make sure the nipples pointing up as a start if not swap them over. Quote
