mitsuruki Posted December 20, 2014 Posted December 20, 2014 is there another way to pour gear oil in the gearbox thats not on the normal top bolt because it wont open for nothing and its ruined now so im checking another way any help > Quote
mikey4410 Posted December 20, 2014 Posted December 20, 2014 not ideally , I dont think so.you really need to get the plug out dude. Quote
akyakapotter Posted December 20, 2014 Posted December 20, 2014 Yes you could use a funel with a bit of pipe in the over flow on the front of the box just don't over fill. Quote
mitsuruki Posted December 20, 2014 Author Posted December 20, 2014 akya which one you mean the one in the front to see the level of it? Quote
akyakapotter Posted December 20, 2014 Posted December 20, 2014 (edited) Big one in front of you there Edited December 20, 2014 by akyakapotter Quote
jellybaby Posted December 21, 2014 Posted December 21, 2014 what about removing the reverse light switch Quote
5e colin Posted December 21, 2014 Posted December 21, 2014 (edited) ^^^^ that should work jellybaby Edited December 21, 2014 by 5e colin Quote
turbo Grant Posted December 21, 2014 Posted December 21, 2014 Or you have a nice breath on top of the box that works well Quote
fiddlersport Posted December 21, 2014 Posted December 21, 2014 good chisel and a few hammer taps should get your old one off so you can replace with a new one, a bit of heat should help ! Quote
