Jay2ohh Posted December 26, 2014 Share Posted December 26, 2014 car went to tuning developments, got it back the infamous fan was on 24/7 never getting close to half way temp say about a quarter up if thatread up on bridging it, gave it a bash, fucked it.un did my initial steps panicing and thinking fuck it ill leave it on 24/7 till i find someone who knows what there doing but its not coming on at all now, its not over heating like but ive not tried to make it over heatSOsome will some wont approve BUT id like help instead please into wiring it into the caram i right in thinking take the connector off the endEARTH oneLIVE wire goes into the in car switchOther live wire goes from switch to 12v battery then obviously when i flick it, the circuits complete and it comes on??ALSO if i drive for a long time it wont overheat but when parked up idling afterwards its like the temp catches up and the needle then moves up but drops when i drive, brand new td low temp thermostat no issues at all, is that normal??cheers joe Quote Link to post Share on other sites
daniel_g Posted December 26, 2014 Share Posted December 26, 2014 Best bet is wire it to a switch yeah but wouldnt use the battery, used a ignition switched 12v instead. They'll be one around the ignition somewhere. Quote Link to post Share on other sites
fiddlersport Posted December 26, 2014 Share Posted December 26, 2014 dont you want to hook it up to a relay ? Quote Link to post Share on other sites
FMuscle Posted December 27, 2014 Share Posted December 27, 2014 Yes you'd want a relay... and a fuse. Quote Link to post Share on other sites
morgey Posted December 27, 2014 Share Posted December 27, 2014 Surely theres a proper fix? Whats wrong with the oem circuit. Cant you just recreate that circuit with a wiring diagram and tuck it out the way under the fuse box in the bay?Is it the issue with the removal of the AC thats left the main fan on permanently that loads of people have fixed normally retaining original use. Quote Link to post Share on other sites
_shaun_ Posted December 27, 2014 Share Posted December 27, 2014 I'd give td a call and ask what they have done that's quite a few starlets they have done it to must be a reason Quote Link to post Share on other sites
Stu Posted December 27, 2014 Share Posted December 27, 2014 What ecu is the car running? If not stock has it been setup to run from the ecu? Might just need configuring? Quote Link to post Share on other sites
Jay2ohh Posted December 28, 2014 Author Share Posted December 28, 2014 completely stock ecu, ive ballsed it up somewhere, so looking for a quick fix now till i get something sorted Quote Link to post Share on other sites
