5e colin Posted January 7, 2015 Posted January 7, 2015 (edited) just a plain old 4efe if she is from 90 to 95 then she has the fat rods ( gen1 ) cynos A Edited January 7, 2015 by 5e colin Quote
daniel_g Posted January 7, 2015 Posted January 7, 2015 If its the same as the JDM Gen1 4EFE thats in the early Jap starlets and the starlet Gi then its a decent lump.Basically a GT engine with different pistons. The one in my 85 was like this.Crank marked 4ETThick rods (look like GT rods)FTE flywheel212mm clutchPink injectorsThread in the block for a knock sensorFTE inlet and TBThermo housing sensors same as a GT100ps ECUDifferent exhaust maniFTE valve springsThink thats itWell worth getting it buddy Quote
daniel_g Posted January 7, 2015 Posted January 7, 2015 Also might be worth taking the gearbox aswell if you can, might be different to the normal N/a starlet boxes.Some Jap N/a starlets came with a 4speed manual haha. Quote
fiddlersport Posted January 7, 2015 Author Posted January 7, 2015 this has the 4 speed manual I just sold a crank and it had the 4et stamped on the crank and that was out of a early uk n/a starlet Just wondering if the cynos has the same crank ? Quote
5e colin Posted January 7, 2015 Posted January 7, 2015 most of that spec u mention daniel is not on a cynos 4efe block !!!!! like springs tb clutch etc the crank is probly stamped 4et indeed as soo many jap 4efe engines have but nothing else is uprated to 4efte spec the crank in my turbo GI block is also stamped 4et but was no knock sensor thread !! Quote
daniel_g Posted January 8, 2015 Posted January 8, 2015 Was just listing those things so he could compare to the cynos and see whats what. Quote
FMuscle Posted January 8, 2015 Posted January 8, 2015 Noticed that on my 4E as well, I was putting the sump on and had the 4ET stamp in my face for a few seconds... Quote
fiddlersport Posted January 8, 2015 Author Posted January 8, 2015 this 4efe engine has the knock sensor, will take a photo of the ecu and take it from there ! My last jdm 4efe had a knock sensor also.... Quote
Starlet__SR Posted January 8, 2015 Posted January 8, 2015 Any difference between the UK spec 5EFE and the JDM spec Cynos engine?Day Quote
fiddlersport Posted January 9, 2015 Author Posted January 9, 2015 200cc, its a 1300cc engine in the cynos Quote
