Thought its about time a made a proper build tread am not new to the starlet Seen owned a few ep82s two ep91s and a lovely ep71 turbo s am currently doing a forged build on my 96 spec glanza a bought with piston rings and bottom end damage here's a few pictures how a got it Since then the cars changed a lot engine was removed and sent to the local engineering garage for a forge build while the engine was away getting built a set in about the engine bay with paint here's a few pictures
10007408_695892880468353_1945595484_n_zp
1622131_677642478960060_582390800_n_zpsd
month down the line engine was built spec is
wiesco 74.5mm low comp pistons
Scat rods
Arp head bolts
Acl bearings
Antenna 1.4 head gasket
cruise valve springs
Genuine toyota oil pump
Genuine toyota water pump
Genuine toyota gasket kit
genuine toyota timing belt
New distributor
new rotary arm
Two days down the line engine was fitted and running sweet had to run it in for a 1000 miles wasn't looking forward to it :( but done it drove the car for about four month on the stock ct9 was running mint now it's off the road again the cars changed a lot since then here's a few pictures
Full spec
Stage 2 forged motor
Body
Genuine varis bonnet
Livesports wings
I'd workz varis bumper (copy)
Livesports spoiler
Braking/handling
Wilwood 4 pot breaks
D2 suspension
2015-01-09-00-25-52--568568978_zpsae2e1c
Lsd box
Helux 4 puck paddle clutch
Td light & balanced fly wheel
Air/fueling/ecu
Apexi power fc
Apex avcr
550 injectors
Sard fpr
3" exhaust
J performance front mount
10904747_922244724466349_1502866000_n_zp
Turbo kit
Race tech top mounted manifold
Race tech decat
GARRET GT2860RS hybrid turbo
HTA billet wheel fitted
Compressor housing machined and polished
.57 exhaust housing
38mm tial wastgate
New exhaust today buddy club spec 2 and new mister r coilover and wheels fitted
Edited by ryan22laird
awesome loving it i will get round to posting what the original spec was for you lol got shit ton of studying to do just now and work .
what clutch you running in it.
Sound man no rush am running a 6 puck paddle
wicked starlet dude. that turbo kit :-D:-D
thanks man the turbo kits awesome :)
