Jozinobi Posted March 27, 2009 Author Posted March 27, 2009 Its still too early to make any judgements guys, have only been at 4k revs!!!I don't have the itbs on yet which would be such a bad idea on a fresh engine.It needs running in first. As for the lsd it has been fine so far but I will watch myself.Will keep you all updated.Joz Quote
Dean @RW-Developments Posted March 28, 2009 Posted March 28, 2009 carnt belive its finally in. good luck with the running in process Quote
rob_bower Posted March 28, 2009 Posted March 28, 2009 Joz man this is awesome news mate she is going to be awesome!! n/a ftw!! Quote
Jozinobi Posted March 28, 2009 Author Posted March 28, 2009 Cheers chaps I have been bolting things on for way too long so the emanage base tune is going to really sort her out.I have decided to stick with the TRD quickshift but utilise the TC gear cable bushings.She should be going into the bodyshop just before easter.Joz Quote
Idrees Posted March 28, 2009 Posted March 28, 2009 Sounds ace, nice one Joz!I'd stick with the TRD too. Quote
Cujo Posted March 29, 2009 Posted March 29, 2009 Good work an bril build! Hoping for my 4 or 5e by year end! Quote
Sparky Posted March 31, 2009 Posted March 31, 2009 Immense mate, I love my clutch and diff feels so much racey'er to drive Glad everything is going well, and I find it impossible for the backend to come out aswell, gives so much more confidenceMore pics Quote
Jozinobi Posted March 31, 2009 Author Posted March 31, 2009 Cheers Lew I have to agree mate, feels like you are in the time attack everytime you go for a drive.Some of the accessories have less power too, the heater is not as powerful as before but still works.The revs rise and drop a bit faster for me due to lightened flywheel and underdrive crank pulley so she stalls easy lol.Something Im gonna have to get used to in traffic... Off to get the oil changed later on.Soooo looking forward to the emanage base tune mate.Will get pics up when she is back from the bodyshop ;)Viewing as intended Quote
Jozinobi Posted April 3, 2009 Author Posted April 3, 2009 500 Mile Oil Change ScheduleStarted at 45,23045,310 - Sorted45,450 - Miles met, changing oil and filter tommorow.45,730 - Emanage timeEP will be going to the bodyshop after easter.Joz Quote
Rich Posted April 3, 2009 Posted April 3, 2009 Awsome work mate gets some vids up of the tuning. Quote
Jozinobi Posted April 9, 2009 Author Posted April 9, 2009 Project Red EP91 5EFHE Tuning Stage UpdateYes you read right from Rebuild Stage > Tuning Stage I took the Red EP to m16chris on tuesday to get a base tune and to make sure the emanage is working properly.It powered up fine but due to being a slight older model it had issues with holding the afr at idle when set by the emanage.The older models are also less compatible with new software features hence the additional adaptors and harnesses.We did a range of tests and sorted a very small wiring issue (bad contact).Launch control works fine.It was obvious that the emanage would need an addition injector adaptor so I will be ordering that soon.I must also check the jumper settings as that may also be the problem (it was originally tuned for a supra!) as the add/trim fuel function may be jump setting related.So it was back on with the 4efe ecu and we took it for a blast down the road with the wideband attached.It was running lean from midrange to top so obviously the 4efe ecu retarding the fuel.I want to get this running right with the emu before moving onto the itbs.Soon as we get this emanage sorted we'll be taking it up for RR and also some fine tuning at the same time.The EP should be running far better than it is and has great potential.Will keep you all updated.Thanks for readingJoz Quote
Sparky Posted April 9, 2009 Posted April 9, 2009 Sweet, Emanage blue has Launch control?Be good to see this bad boy tuned Quote
Jozinobi Posted April 9, 2009 Author Posted April 9, 2009 Me too bro!Im using Ultimate not Blue afaik blue doesnt have the launch control feature. Quote
Jozinobi Posted April 10, 2009 Author Posted April 10, 2009 Had the emanage ultimate open tonight to check the jumper settings. They all seem right to me but have asked my tuner to be double sure.Joz Quote
SiCaln Posted April 10, 2009 Posted April 10, 2009 Awesome work man, you're gonna beat me to the rollers at this rate Quote
Sparky Posted April 10, 2009 Posted April 10, 2009 OOhh my bad, why did I think you had a Blue? lol Quote
Jozinobi Posted April 10, 2009 Author Posted April 10, 2009 keep up the good work sensei ! Just noticed this Leo Cheers bro! Quote
Jozinobi Posted April 10, 2009 Author Posted April 10, 2009 Awesome work man, you're gonna beat me to the rollers at this rateThanks Si.At the end of the day bro, its not a race or competition.I just want to get everything sorted so this EP can run at its full potential.Hope you get sorted soon too.Joz Quote
BAZ2CRAZY Posted April 12, 2009 Posted April 12, 2009 Id love to appreciate this to the fullest but i have no idea what a 5efhe is? is it a 5efe? whats the h? apart from me not know whatas going on you seem to be doing everything spot on, effort mate. Hope you get it finished succesfully.Mitch Quote
Mikey Jay Posted April 12, 2009 Posted April 12, 2009 The 5efhe is basically a better 5efe, with different internals, and came with better inlet and exhaust manifolds too.Was found in the Cynos (JDM version of the Paseo), and produced something like 114bhp as standard compared to the UK market 5efe which made 89bhp Quote
Jozinobi Posted April 12, 2009 Author Posted April 12, 2009 @Jaystar - Won't be too long until my visit dude, had no idea you were so near Kirky, would be rude not to visit.@Mitch - Thanks for your comments mate.What I've done is used the top half of a JDM 5EFHE from a Toyota Sera which includes the head which has been port and polished and valve cut, this head includes the beneficial 5EFHE higher lift cams and from the bottom half of the 5EHFE I've taken and used its slightly higher compression pistons and stronger rods. I've used my original 5EFE bottom end which was mint upon disassembly. I've also used stronger valve springs to reduce valve float at higher revs.The 5EFHE from the Sera originally made 110bhp and thats using a 5EFHE ecu and higher octane jap fuel. It revs to 7200rpm as standard and makes maximum power @6400rpm which is beyond what the 4EFE ecu is set for @6200rpm.The engine will be tuned by emanage ultimate next week so that everything I have done will work to its potential as from the test mapping, everything is running lean on the 4EFE ecu up top which is safe but far from ideal as quite a bit of potential power is lost. By late next week I should be running proper air/fuel ratios and also have a higher rev limit of 7500rpm and launch control.Im still taking it to be RR'd and also fine tune it whilst Im there, as recommended by my tuner. After that, once she is running properly, I can work on the itbs. At the moment Im using a hotshot 4-1 exhaust mani and the corolla tubular inlet mani. You'd be suprised how much your engine will benefit from a proper tune especially when bolting on mods throughout the years like myself.For the engine to rev more easily I'm using an aftermarket lightened flywheel and underdrive crank pulley. To put more power to the wheels Im also using TRD engine mounts and a section engine damper as well as a QUAIFE lsd. For response Im using a stage 2 exedy racing clutch. As you may have seen the suspension is totally sorted bar it being very hard and stiff. I may choose something with more adjustability a little later.All in all, this is my quest to have my n/a ready for some gruelling track days so that she has a purpose and to give me more enjoyment. On the public road this cannot be achieved.I will keep you all updated and hopefully she will be in the bodyshop for her makeover after the tuning.Thanks for reading.Joz Quote
Jozinobi Posted April 27, 2009 Author Posted April 27, 2009 Project Red EP91 5EFHE Body Stage UpdateMy tuner is busy with personal things at the moment so Im taking this chance to get the bodywork done She may be back by the end of week and should look like a different car.Can't wait tbh and can then finally enter the montly calendar competition lol.Until then still waiting for the tuning which Im really itching to get sorted.The car drives great but should be much better.Joz Quote
Mikey Jay Posted April 27, 2009 Posted April 27, 2009 Cool beans amigogoI'll await photos like an eager beaver Quote
