anyone got any photos of how they mounted the pump? all wired in etc just can't find a good way to mount it
Im having trouble of where to mount mine gunna have to be under the dash and then run hoses through bulkhead
U can see mine mounted in the last pic Phil put up it's just below the wing mounted to the chassis leg
shaun, remind me how you made the low pressure line? is it just a cut and jubilee job?
yea from the rack theres an oem hard line that bolts onto it and then attached to a oem rubber hose. i just uncliped the oem rubber hose and jubileed a new fuel/oil hose onto that and ran it along side the high pressure line onto the saxo pump. handy enough the saxo high pressure and low pressure are the same threads/ sizes as the starlets. where mines mounted the hole below the abs servo is directly above that so the expantion tank just runs straight onto the pump aswell.
  • 1 year later...
sorry for digging up an old post but no one has said how the wired these up i wanna do something like this on my gt rep ive a gt rack already and column as there different
but what about wiring
