Riiight should I take it off then?
Or things I can check to make sure it's okay?
Spec of the car atm is:
FMIC
tubular mani
Recon CT9
Blitz Boost gauge (boost steady at 8psi)
Greddy BOV
HKS turbo timer
That's all the mods as far as I know and the car drives perfect
FCD - Fuel Cut Defender - removes stock ecu's fuel cut at 0.8bar - with this you can boost over stock limit, but your fuelling need to be checked also.
That on the ecu is a hks fcd. Will be wired into the live, ground and map sensor to intercept/modify the signal. Bottom picture is a fse fuel pressure regulator.
Guessing at somepoint someone has used the fcd to remove fuelcut and up the boost, using the regulator to fuel enough. If you dont need the fcd remove it or turn it to setting 12 which is off. Or get it on A dyno to see if the engines fuelling correctly as the fcds lean it out
The problem is I don't know if I need the fcd or not, according to the boost gauge it's only boosting at 8psi but I'm really not sure because it seems like more
Oh good :) well from the outset it looks like a half decent setup, just want to get it on the rollers and see what's what and what power it's actually making
And thanks for answering another question I should probably know already 👍
