chad94 Posted April 10, 2015 Share Posted April 10, 2015 Right so I brought a competition 6puk clutch and flywheel not so long back. Only got round to fitting it last week and all was fine for the first few days. Pedal was great and it drove A dream.However I did a long journey the weekend and I notice the biting point was right at the top. Also it was hard to select gears every now and then which I found strange as it wasn't all the time.. Aswell as finding it hard to select gears sometimes it won't come out of gear but it doesn't fully disengage the clutch so I can't actually stop which worried me a little. The clutch was brand new withh new release bearing. Anyone had any problems with competition clutches before? Any ideas? Feels like there's an issue with the pressure plate maybe? Quote Link to post Share on other sites
nofear Posted April 11, 2015 Share Posted April 11, 2015 i had the same problem bought a competition clutch 6puk and after maybe 2 weeks it started giving me problems could not get the car out of gear and sometimes when i was at a traffic lights and put first gear the car would start moving by it self even with my foot fully on the clutch. i had to change the clutch and now its good just have to drive slower because the stock cant handle extra horse power very well. hope it helps Quote Link to post Share on other sites
AdamB Posted April 11, 2015 Share Posted April 11, 2015 There was a problem with them a little while back where the pressure plate ( I think ) would touch the inside of the bell housing. Probably more info over on TGTT about it, but I'm sure Browner had a similar problem so might be worth firing him a pm dude. Quote Link to post Share on other sites
Whitenoize Posted April 11, 2015 Share Posted April 11, 2015 CC have a very good customer service system it's a pain that its failed in the first place but I've no doubt they will give you a replacement a mate of mine had a problem with his and its was sorted out asap no messing about he was very impressed Quote Link to post Share on other sites
akyakapotter Posted April 11, 2015 Share Posted April 11, 2015 There was a problem with them a little while back where the pressure plate ( I think ) would touch the inside of the bell housing. Probably more info over on TGTT about it, but I'm sure Browner had a similar problem so might be worth firing him a pm dude. I have this problem with my spec clutch Quote Link to post Share on other sites
mikey4410 Posted April 11, 2015 Share Posted April 11, 2015 I have a cc and its bwwn on for a good amount of time now daily driver and cant fault it.very happy widdit.sucks that a few people have had issues with six puckers .weird Quote Link to post Share on other sites
Ollieh17 Posted April 11, 2015 Share Posted April 11, 2015 I had the same problem as nick, turned out the spec 6 was actually for a mr2 not a glanza Quote Link to post Share on other sites
5T4R7ET N/A Posted April 11, 2015 Share Posted April 11, 2015 It might be the extra strain that is being put on the clutch slave cylinder that will be causing the problems Quote Link to post Share on other sites
Mitchell Posted April 12, 2015 Share Posted April 12, 2015 I've been having this exact problem with my spec 6 puk, i bled the clutch system wich temp fixed it, i then unbolted the slave an tilted it up so the nippple was at the very top, a lot of air trapped in the system, then ran fresh fluid thru, fixed it for a couple days, so it may not be a problem with the clutch, but the slave cant take the added pressure, I've got a slave on order from td, ill let ya know in a couple days if it sorts it , easier than getting gearbox an clutch out again, also it drove lovely when i had bled the system Quote Link to post Share on other sites
Ollieh17 Posted April 12, 2015 Share Posted April 12, 2015 Import car parts sell an uprated slave cylinder for £25 or so Quote Link to post Share on other sites
Sefton-EP91 Posted April 12, 2015 Share Posted April 12, 2015 I've been having this problem recently with my spec 6 puk. It's strange because some days it will be fine and the next it will be awful. I'm thinking it could be the release bearing because somtome a I can feel it engage without even lifting the clutch and the car starts to roll like the clutch is engaged. I had TD bleed my clutch and that helped for about 2-3days. Now it's gradually got worse. I'm going to bleed clutch once more to see if that sorts it and if not I'll set at getting the release bearing replaced. I'll try source an LSD for when I do take the box out. Quote Link to post Share on other sites
Glanza-Ben Posted April 13, 2015 Share Posted April 13, 2015 Had this aswell spec 6 is shit thats the answer Quote Link to post Share on other sites
chad94 Posted April 13, 2015 Author Share Posted April 13, 2015 (edited) I can't see it being an hydraulic Problem, I've bled the clutch when I fitted i. The slave doesn't leak or isn't damp etc and had full movement when watching it whilst a friend opoperated the clutch. I've done just shy of 400 miles on the clutch now so I'm past the run in period recommended so I'd of thought I'd of had an issue before now if it was the slave, my guess is somethings about to fail on the clutch itself :/I've spoke to the guys at id-workz today and they seem keen to help me resolve the issue, awaiting a phonecall tomorrow to see what they are going to do about it.Hopefully it's just a straight forward job of replacing the clutch and release bearing and job done. Thanks for the input guys, kinda glad it's not just myself who's had issues! Edited April 13, 2015 by chad94 Quote Link to post Share on other sites
Mitchell Posted April 17, 2015 Share Posted April 17, 2015 Soo I've put a new slave on and it feels so much better, massive improvement, just hoping it lasts Quote Link to post Share on other sites
Sefton-EP91 Posted May 23, 2015 Share Posted May 23, 2015 (edited) Any more on this mate? Did a new slave cylinder last? Thanks Edited May 23, 2015 by Sefton-EP91 Quote Link to post Share on other sites
kevmcc90 Posted May 23, 2015 Share Posted May 23, 2015 I had been having same sort of issues as you mate and I've fitted mt old flywheel and that seems to have sorted the clutch holding on issue. When I compared flywheels the new one was slightly thicker. Might be worth a try? Quote Link to post Share on other sites
Sefton-EP91 Posted May 23, 2015 Share Posted May 23, 2015 Mine can't be the flywheel because I'm still on the standard one and still have this problem. Mitchell replaced his slave cylinder and it seems to have made his a lot better so I'll give that a try thanks Kevmcc90! Quote Link to post Share on other sites
kevmcc90 Posted May 23, 2015 Share Posted May 23, 2015 No problem mate, thought I'd suggest it as I changed everything else and that's what worked for me. Good luck! Quote Link to post Share on other sites
