GavinsBeard Posted April 13, 2015 Posted April 13, 2015 As above, not sure if it something bad or it just needs a small service but my cars been a bit sluggish and wondering if there's really anything I can quickly do to maybe get it back to its former glory or just get it serviced and go from there Quote
morgey Posted April 13, 2015 Posted April 13, 2015 Check its boosting properly.compression test, are they within 1barif they are ok a full service.overhaul the ignition system. Quote
GavinsBeard Posted April 14, 2015 Author Posted April 14, 2015 Check its boosting properly.compression test, are they within 1barif they are ok a full service.overhaul the ignition system. As much as i'd love to own a turbo i only have an N/A atm :/ Don't know if you've got any tips on the 4EFE? Quote
morgey Posted April 14, 2015 Posted April 14, 2015 Ahh i see. Compression check. Check timing.Plugs, filters, fresh oil. New dizzy and leads wont do any harm. Quote
5e colin Posted April 14, 2015 Posted April 14, 2015 whats the milage on her might just be high milage looseing overall performance Quote
GavinsBeard Posted April 14, 2015 Author Posted April 14, 2015 Ahh i see.Compression check.Check timing.Plugs, filters, fresh oil.New dizzy and leads wont do any harm. Ah cheers, i'll check the timing and change the oil it's had a new dizzy and leads about a month ago whats the milage on her might just be high milage looseing overall performance 116k Quote
mikey4410 Posted April 14, 2015 Posted April 14, 2015 116k isnt that much on a jap car,especially an n/a jap car.if its been maintained well it should be 5/10 psi of what psi it had originally.as above refresh ignition and do a comp test. Quote
MARC MOSS Posted April 14, 2015 Posted April 14, 2015 Sounds like it just needs a good service mate, the difference can be quite noticeable Quote
daniel_g Posted April 14, 2015 Posted April 14, 2015 Change the fuel filter and spark plugs, ee if it makes a difference. Quote
GavinsBeard Posted April 14, 2015 Author Posted April 14, 2015 Gonna get it serviced at the end of the week see if that makes a difference, if it dosen't, New HT Leads, Spark Plugs, dizzy and a comp test would probably be best? Quote
morgey Posted April 14, 2015 Posted April 14, 2015 Comp check will just tell you if its worn out. Id expect around 160-180psi on a good n/a 4efe at a guess? (Someone confirm)Post your results up and someone will let you know how they fair. If youve done the dizzy and leads dont worry about them. Plugs, oil, oil filter, fuel filter, air filter, check timing. I think theres a procedure for the timing that involves bridging te1 and e1 in the little black diagnostics port then starting the car and checking the timing. Quote
