Not really looked into them as I know they can be a engine killer!
Can they be used a launch control as in building boost at a stand still
Only asking as my ecu doesn't have a launch control feature and I'm chasing times on the 1/4 mile and I seem to bog down abit off the line
Ive been launching my 85 at about 6-7k rpm, been working ok so far, although im not running a lot of boost, only 0.6.
The AVCR Black does boost by gear im sure.
I have the ecu and a hks evc6 controlling boost by gear problem is the fwd launch fine by the wheels spinning the 4wd wants to bog down unless you go with dans approach haha and I've done 2 gearboxes and 3 clutches already 😆
Bee*R's work in a different way to the omex as far as I'm aware. Bit more crude.
I wouldn't run a Bee*R, last one i fitted to a GT it lasted about 2 1/2 days :thumbsup::sad:
  • 1 month later...
