motion Posted May 28, 2015 Posted May 28, 2015 Hi mates. ..is it possible to change the rear axle bushes without removing the axle off the chassis? Removing panhard rod and bolts will give enough clearance to work on it? Quote
rwdrev Posted May 28, 2015 Posted May 28, 2015 it could be possible but its getting the old 1's out thats the probplem, even with my axle off i struggled abit to get the outer casing of the old bush out. is not a big job, easyr with axle out tho Quote
Johnboy GT Posted May 28, 2015 Posted May 28, 2015 Not supposed to leave the metal casing in on the GT rear beam for the poly bushes or did I misread that?John Quote
rwdrev Posted May 29, 2015 Posted May 29, 2015 Not supposed to leave the metal casing in on the GT rear beam for the poly bushes or did I misread that?Johnthe outer casing of the old bush needs to be hacked out, so burn the bush out, then hack-saw the remaining outer shell, and chisel out. the original bushes are made inside this ring then pressed in. Quote
Ollieh17 Posted May 29, 2015 Posted May 29, 2015 On a glanza rear beam burn the rubber out and keep outer casing metal case in there Quote
Johnboy GT Posted May 29, 2015 Posted May 29, 2015 Thanks Ollie and rwdrev. I knew I read that a casing needed kept somewhere.John Quote
motion Posted May 29, 2015 Author Posted May 29, 2015 How about a ep91 NA? Let the ring an or cut it out?Where can i get the polybush for the rear axle? Quote
Calum122 Posted September 27, 2015 Posted September 27, 2015 Don't mean to dig up an old thread. So this is a GT rear beam. We are talking removing the rubber, and then the metal housing, much like the engine mounts? Quote
glanzadude Posted September 27, 2015 Posted September 27, 2015 Would also like to know how to fit the polys to a GT also Quote
morgey Posted September 27, 2015 Posted September 27, 2015 If youre not sure remove the old bush and leave the metal ring in. If the new bush doesnt fit remove the ring. Quote
Calum122 Posted September 27, 2015 Posted September 27, 2015 Cheers Morgey. I know that sounds obvious but it is still good advice. Whatever happens I'll be sure to post back for others to find. Quote
Calum122 Posted October 3, 2015 Posted October 3, 2015 Just to finish this then. With the ep82 55mm bush. I chain drilled the rubber bush out. Then you need to remove the outer shell that the mount was attached too. I just did the old hack saw it down the middle and chisled it out with a screw driver. New bushes just fit straight into that Easy enough to do. Just a tad time consuming. Quote
glanzadude Posted October 3, 2015 Posted October 3, 2015 That's super where did you get the poly bushes and how much? Quote
Calum122 Posted October 3, 2015 Posted October 3, 2015 ID Workz and £55. Does that make sense above or do you need me to clarify anything. Quote
rwdrev Posted October 4, 2015 Posted October 4, 2015 set fire to the bush and it drops out (blow torch, or metal container containing oil, diesel, petrol, thinners, anything that burns for ages, always works for me), then there should be a 2mm (if that) thick ring left in the hole, hacksaw through it, chap it out with hammer and chisel, insert new polybush, job jobbed. i used powerflex bushes in mine. http://www.ebay.co.uk/itm/Powerflex-Poly-Toyota-Starlet-Glanza-Turbo-EP82-EP91-Rear-Beam-Mount-Bush-/380663925776?hash=item58a1568c10 Quote
