  On 5/31/2015 at 7:20 PM, fordie_glanzaV said:
I dont think ill b taking them back to the fuse box.. unless i have to..
Take plugs off protect ends and wrap into loom i thinks :) cheers
that's fair enough but it just a option as I completely removed all the loom for the abs and the amount of crap u end up is shocking but handy for me as I use the good wire to repair worn parts of my engine loom lol
Abs doesn't run to the actual engine ecu, it has a separate unit under the dash - drivers side. chop it all out and remove that.
Im running a saxo/106 electric pump too. its not hard to wire in / fit.
The wiring for the ABS ECU runs up the OS wing, if you remove it then you'd be best to seal up the grommet which the wiring goes through into the car. The ABS ECU is held in by a couple of 10mms kinda above where your right knee is.
