Duduglanza Posted June 17, 2015 Posted June 17, 2015 Anyone here have managed to make some Good detcans. U tried 3 methods and none if them is working. Tried flattening a copper pipe and attach everything to earmuffs.. didnt work..tried an elctronic one using Listen Up device but the alternator frequency is the only tbing i can hear. Tried even using stetoscope but the sound is very low and i can barely hear anything while reving.I saw one live.. from a tuner using a stetoscope and i duplicate it but still no luck Quote
Stu Posted June 18, 2015 Posted June 18, 2015 If you wanted to try again with an electronic version you can use a bosch donut style knock sensor from a SR16/18/20 Nissan, a long shielded fly lead (shielding is important), a small 5-15w 12v amp (ebay/aliexpress) and a set of headphones. Works well. Quote
Phil Posted June 18, 2015 Posted June 18, 2015 (edited) If you wanted to try again with an electronic version you can use a bosch donut style knock sensor from a SR16/18/20 Nissan, a long shielded fly lead (shielding is important), a small 5-15w 12v amp (ebay/aliexpress) and a set of headphones. Works well. Sensor http://www.ebay.co.uk/itm/New-Black-Subaru-Knock-Sensor-Part-For-Legacy-Impreza-Outback-Forester-1999-2002-/390569716388?pt=LH_DefaultDomain_3&hash=item5aefc4eaa4 Wire from sensor to amp http://www.ebay.co.uk/itm/2-Core-Screened-Shielded-Sensor-Wire-Ideal-for-Crank-Cam-Speed-Sensors-sold-perM-/111611069787?pt=LH_DefaultDomain_3&hash=item19fc89c55b Amp this http://www.ebay.co.uk/itm/200W-12V-Mini-2CH-Hi-Fi-Amplifier-AMP-Radio-MP3-Stereo-for-Car-Motorcycle-Boat-/251872406806?pt=LH_DefaultDomain_3&hash=item3aa4c3ed16 or this http://www.ebay.co.uk/itm/40W-12V-Mini-Hi-Fi-Stereo-Amplifier-Amp-Radio-MP3-for-Car-Motorcycle-Boat-Home-/251693793837?pt=LH_DefaultDomain_3&hash=item3a9a1e822d and some big bum headphones http://www.ebay.co.uk/itm/NEW-BOX-Logitech-UE-4000-Headphones-WHITE-/161717197726?pt=LH_DefaultDomain_3&hash=item25a7189b9e Phil Edited June 18, 2015 by Phil Quote
Stu Posted June 18, 2015 Posted June 18, 2015 Both of those amps are far too powerfull - you will find that even with them dialed right down you'll deafen yourself, that's the issue I have with mine and its only 15w. Quote
Phil Posted June 18, 2015 Posted June 18, 2015 Both of those amps are far too powerfull - you will find that even with them dialed right down you'll deafen yourself, that's the issue I have with mine and its only 15w. ah right. link me a suitable amp Phil Quote
gorganl2000 Posted June 18, 2015 Posted June 18, 2015 (edited) Anyone here have managed to make some Good detcans. U tried 3 methods and none if them is working. Tried flattening a copper pipe and attach everything to earmuffs.. didnt work..tried an elctronic one using Listen Up device but the alternator frequency is the only tbing i can hear.Tried even using stetoscope but the sound is very low and i can barely hear anything while reving.I saw one live.. from a tuner using a stetoscope and i duplicate it but still no luck hey boss...i made an electronic DIY detcan using listen up....will try to write it up for you later on...made a few mods....it works perfectly i'd post some pics, BUT not sure if its only for paid members as i'm not one http://www.ukstarletowners.com/topic/89360-det-cans/ take a look at that link...it has the two sites i used to make my diy electronic detcans before i put the mic in the stud ring, i made sure to put a little epoxy around the outer/side casing of the mic ----NOT in front the mic itself.....i THEN made sure to push the mic completely down to the bottom of the stud ring---again, you dont want any epoxy or other material in front of the mic face as this is where the sound is picked up......i THEN packed behind the mic/wire with epoxy right up to the top of the stud ring the stud ring was a pretty snug fit for the mic....i'll try to get the size when i get homegot it from the hardware store pretty cheap i used 16 or 18 gauge speaker wire to run from the listen up unit to the mic----its pretty heavily insulated Edited June 19, 2015 by gorganl2000 Quote
Sudden Posted June 20, 2015 Posted June 20, 2015 (edited) https://imageshack.com/i/ip310HCuj reinforced tubing shoved into an electrical eye fitting(copper). More important is where you bolt it. Mine is bolted to the centre intake manifold bolt and besides the valvetrain noise, pinking sticks out like a sore thumb and is easy to hear. Edited June 20, 2015 by Sudden Quote
Duduglanza Posted June 21, 2015 Author Posted June 21, 2015 hey boss...i made an electronic DIY detcan using listen up....will try to write it up for you later on...made a few mods....it works perfectly i'd post some pics, BUT not sure if its only for paid members as i'm not one http://www.ukstarletowners.com/topic/89360-det-cans/ take a look at that link...it has the two sites i used to make my diy electronic detcans before i put the mic in the stud ring, i made sure to put a little epoxy around the outer/side casing of the mic ----NOT in front the mic itself.....i THEN made sure to push the mic completely down to the bottom of the stud ring---again, you dont want any epoxy or other material in front of the mic face as this is where the sound is picked up......i THEN packed behind the mic/wire with epoxy right up to the top of the stud ring the stud ring was a pretty snug fit for the mic....i'll try to get the size when i get homegot it from the hardware store pretty cheap i used 16 or 18 gauge speaker wire to run from the listen up unit to the mic----its pretty heavily insulatedI see. The listen up device is good but its picking too much interferance. Maybe i will try it with different wires as i used some normal speaker wires. Quote
Mad Mike EP82 Posted June 21, 2015 Posted June 21, 2015 Anyone here have managed to make some Good detcans. U tried 3 methods and none if them is working. Tried flattening a copper pipe and attach everything to earmuffs.. didnt work..tried an elctronic one using Listen Up device but the alternator frequency is the only tbing i can hear. Tried even using stetoscope but the sound is very low and i can barely hear anything while reving.I saw one live.. from a tuner using a stetoscope and i duplicate it but still no luck copper pipe how was it connected? Quote
Duduglanza Posted June 21, 2015 Author Posted June 21, 2015 I pushed the pipe intotye copper pipe.. than flattened the frond piece and drilled a hole. Quote
Mad Mike EP82 Posted June 21, 2015 Posted June 21, 2015 I pushed the pipe intotye copper pipe.. than flattened the frond piece and drilled a hole.And you can't hear anything? Quote
Duduglanza Posted June 21, 2015 Author Posted June 21, 2015 I hear the engine running on idle but could hardly hear anything while i start driving. Quote
Mad Mike EP82 Posted June 21, 2015 Posted June 21, 2015 if you have done it like this and are bolting it to the correct place don't see why you cant hear anything. http://www.gtrpwr.com/showthread.php?t=1589 Quote
