epnineone Posted June 28, 2015 Posted June 28, 2015 Hey guys, so the other day I attempted a burnout in my n/a ep91 starlet and blew the diff and snapped the rear gearbox mount, it couldn't handle all 74bhp from the irish model 😂 so I was able to pick up a 4 speed box from a 1.0 litre ep82 starlet for free and was wondering will it fit to the 4efe block and are the mounts different (I know I need the 1.0 litre driveshatfs) thanks for any info on this Quote
dave-gtturbo Posted June 28, 2015 Posted June 28, 2015 Looks like they swap just fine - here's where I got my info: http://www.toyotagtturbo.com/forums/showthread.php?17456-what-the-diifference-between-2EFTE-engine-compare-to-4EFTE Dave Quote
daniel_g Posted June 28, 2015 Posted June 28, 2015 Some JDM EP82 N/a had the 4speed box, and they had a 4EFE. So if its the same box then it should fit.Fire some pics up of the mounts on the box if you can. Quote
epnineone Posted June 29, 2015 Author Posted June 29, 2015 I'll get a pic of the mounts in the morning, the rear one looked similar but I'm not too sure of the front mount Quote
Stu Posted June 29, 2015 Posted June 29, 2015 Yes will fit fine. Ive converted from 4spd to 5spd heaps of times Quote
epnineone Posted June 29, 2015 Author Posted June 29, 2015 (edited) Mounts are definitely the same, I checked this morning. . was talking to a mechanic friend and he said that I'll need different hubs as the splines are different on the 1 litre shafts, anyone have any info on this? Thanks! Edited June 29, 2015 by epnineone Quote
epnineone Posted June 29, 2015 Author Posted June 29, 2015 Yes will fit fine. Ive converted from 4spd to 5spd heaps of timesHubs shouldn't be a problem then should they? Quote
5e colin Posted June 29, 2015 Posted June 29, 2015 ha haha your na 4efe is going to be soooooo slow its not suited mate best to stick to a na 5 speed or cynos b box u will regret going 4 speed trust me they suck on a daly also there is nooooooooooooo way your 75 bhp na blew the box its impossible its probly urselve that did the damage Quote
maddox710 Posted June 30, 2015 Posted June 30, 2015 I know someone with 200 more hp run a na box and was fine and took a good beating Colins will be right Quote
epnineone Posted June 30, 2015 Author Posted June 30, 2015 Well the diff is blown and it's needs a new box, got the four speed for free so it's going in for the time being, I'll most likely be going 4efet in which case if the 4 speed doesn't hold up ill get a 4efte box Quote
epnineone Posted July 3, 2015 Author Posted July 3, 2015 4 speed went straight in no problems it's running again.. there is a faster launch woth the 4 speed but is slower on the high end.. acceleration has increased though Quote
5e colin Posted July 3, 2015 Posted July 3, 2015 thats only in your head mate infact it will be slower u think its faster because you can stay longer in gear it will go of the clock in 3rd 5 speed is always going to be faster because the gearing is closer together your cruizing speed rpms is going to be higher to now Quote
gorganl2000 Posted July 3, 2015 Posted July 3, 2015 i drove an ep70 with a 2e engine and 1e 4 speed gear boxit moved off fast...accelerated nicely....BUT then seemed to run out of puff very fast in 4th gear and felt flat at higher rpm....like it was straining was a blast to drive up to around 140km....lol maybe some of these boxes have different ratios and final drives??....so it maybe hard to compare Quote
richardc9052 Posted July 8, 2015 Posted July 8, 2015 4 speed box is a mistake. I ran 4efe with both 4 and 5 speed na boxes. Then I ran 4efe-t both 4 and 5 speed and the 4 speed kills the power and hits the Rev limiter at not much over 100mph. So it's slower all round Quote
