well after much much misery of getting rid of my gt rep I decided to get another Toyota I had always wanted a proper glanza v and loved the sudden kick of boost so I bit the bullet and bought this little beauty
as of now I haven't done a thing to it but ive a few small things I do want to do nothing exterior wise is changing mostly interior stuff but that will be later on anyways a bit of a spec list of what she has
bilstein shocks and apexi lowering springs
blitz dumpvalve
apexi pencil turbo timer
HKS adjustable actuator
full blitz nurspec exhaust system
Jperformance decat
TRD leads
oem front and rear lips
apexi airfilter
HKS fuel cut defender
15" rays work wheels wrapped in brand new tyres
98 spec rear lights
TRD gearknob
momo steering wheel
drilled and grooved discs
cam cover filter
i'll let the pictures speak for them selves the pics do the car not justice of how clean it actually is
will take some better pictures of it tomorrow with a decent camera
Edited by JDMfreak
few more pictures to ad to the thread tbh honest there's not much I can do to the car at the minute its all been serviced up so just keeping it clean and doing silly jobs like undersealing and small tidy jobs in engine bay anyway a few pics I took yesterday after a wash and turtle wax sealent applied
excuse the drivers indicator I will be ordering a new lense
you gonna keep this now :-p :p
the way this thing pulls boost I surely am I haven't a boost gauge so I dunno what boost im running but by god its quick I may get a boost gauge fitted to see what im running
forgot to stick a pic up of the engine bay
i'll more than likely go hybrid or similar fensport blitz along them lines
Good lad blitz is a proper turbo keep it up she looks super smart :D
cheers mate the standard one on it at the minute is doing a great job so it gives me time to save up for a turbo mainly im focusing on underneath
protection and small handling mods for the minute going to give the bay a quick clean today if rain stays away maybe paint a few bits just to tidy them up
  • 2 weeks later...
Right time for an update going to get cracking on with doing my under body tidying need to order some new bits and pieces drop links/ball joints
and some paint
also need to remove my callipers hit them with a wire brush and paint them. not sure on colour probably purple or something to match new wheel bolts
anyway my latest new mod oem rear speakers cant tell ya how much I like these look better than the 6x9's also picking up some steel to make some braces c pillar floor brace and rear strut brace
anyways some crap pictures need to get a decent phone
got my glow barrel light and foot well light fitted thanks to chrisssahhh on here for giving me a bit of wiring info
didn't get any pictures yet as was to bright when I did them and my phones flat
next on my list seats these 96 spec ones are driving me mad so going to have a mooch around local breakers see if there's anything in there I like
or make a few calls
Please leave on the 96spec bumper too
bumper is staying put its fits that year of car and has just been painted along with front lip and is 100% not a cut or nip anywhere
cheers rich really need to change it looks very bog standard
right after a lot of head scratching I found the culprit of my knock at passenger side engine mount of gearbox is gone so have ordered a brand new set of JD tunning mounts
should have them here next week or so looking forward to getting them fitted
also noticed I had a small flat spot through the revs put this down to ignition timing been out every so slightly as at times I could here a pop from exhaust when slowing off I bought my self a brand new sealey timing light with a dial to advance it or set it to stock.
after resetting the timing I noticed it would hop so ive put it down to a worn arm on distributor so may get a new distributor while im at it a new rotor arm and cap will be getting fitted aswell
few little bits to ad to the list ordered a boost gauge nothing fancy better than no boost gauge
also going to order a livesport rear spoiler and some new shocks if funds allow
right time for an update received my jd tuning mounts today and set about fitting them also got my boost gauge fitted aswell as that turned up
right I had a suspicion my engine mounts were wanked as I could keep hearing a slap from my gearbox mount when taking of and stopping little did I know how bad it was and my rear engine mount that was just as bad here's a few pics of the old mounts just goes to show they don't last forever
front gearbox mount
and out
and new one fitted
rear mount :/
all sealant removed bush don't look bad but spot the welds around the metal part of the bush why I don't know
all apart and bush out
ground the welds down and gave the sleeve a rub of a file to remove any sharp edges
forgot to take a pic of that fitted but got the drivers side mount done as well wasn't actually bad small split in it but very good
shame I have to cut it out but no point leaving one odd one out
drivers side refitted
well got them all fitted back up engine is solid not a nudge outta it and when I started it fuck me it rattled the car haha
need to get a few pads around stuff to quiet things down but other than that very impressed with them no need to look at them for a good while
also while I was at it fitted my blitz 42mm boost gauge all I can say is wow its tiny haha but does the job and looks the part will be getting a proper pod or holder for it more than likely will fit it into a modified dash vent to hold the gauge
excuse the crap on dash need to find something to dissolve superglue and the double sided tape mess
and the tidy way to run wires and pipes haha
That a red NOS button I see? Haha get her plug n play for now :)
haha no previous owner wired horn upto it bit ignorant and bright haha,, may start saving for a plug and play ecu €500 over here for one
Be one of the best mods to go for starting out, my horn doesn't even work suppose you don't need one been in front all the time :D
