What would be the best tool to use to cut a couple of holes in a body panel? I'm installing a Glanza plate surround and reverse lights in a UKDM tailgate so I need the holes for the lights. My current thought is drill the corners then try and get a pair of tin snips in there, but there's got to be a better way.
Dremmel :thumbsup:
Might be the winner here, I'm just not convinced my ancient Dremel is up to it.
Gas axe
I'd love to, definitely the easiest way but I really cbf to take the tailgate off to do it and a gas axe would get... Interesting haha
A dremel or you can buy a drill bit that you drill a hole and it cuts aswell
Got any links to that kinda bit? I had a look on screwfix but couldn't find anything.
holesaw
Might do this to flesh out the middle, less material to remove.
Hammer
Hahahaha, the sledge is never far away.
You can buy a dremmel kit for argos for 25 quid comes with the tool and like 150 attachments.
As long as your dremmel spins mate just get some decent little cutting disks and it will work just lovely.
Good call, didn't realise it would be that cheap. On order now :thumbsup:
I was just joking with the gas axe haha
Would definitely get the job done, though! Hahaha
plasma cutter :)
Sure, let me just take a loan out against my car to buy one :p
  • 3 weeks later...
I'd recommend the Dremel option, but cheap Dremel cutting discs or ebay specials will just shatter, so get decent ones.
Edited by Arnold
