If they are leaking, chances are buying new damper will be cheaper than getting them rebuild.
Give BC Racing a ring to see how it goes.
The only thing I would say is if two is leaking, then chances are the other two aren't too far behind.
You need to decide if it is worth throwing money into this used suspension anymore.
That is the risk of buying use suspensions... it is a wear and tear item.
A new set of suspension that carries a warranty may cost more, but they carry a much smaller risk should anything happen.
Good luck.
Jerrick
Good luck.
Jerrick
Cheers mate will do that first:)
  • 1 year later...
Idrees lol
Sorry of course lol
Can you tell me what the normal spring rate is that you usually sell on a set of BC's ?
And can you order me different spring rates and replacement parts if I needed them?
Phil
Edited by Phil
6kg front 5 kg rear
I'm on 8kg front 7kg rear and still not happy this is circuit and hillclimb use and using Pirelli rx7 Tyres similar too what you use phil
Edited by glanzagee
6kg front 5 kg rear
Guessing they've changed them since i got mine as they used to be F6/R4 but that was a few years back
Tbh 6/5 was good for fast road use would suck up a lot of the holes/bumps &yumps but for a circuit or smooth road going round bends I had issues with the inner rear wheel cocking up at least 8inchs and the wheel diagonally too the inner dive in too much heat build up and loss of traction etc etc
Yes thinking of going a little stiffer but nothing too rash as I'd like to do a few Hillclimbs and they are far from smooth over here (we use public roads)
Phil
No tq adjustments in the map if anything I need more tq but the gearboxes tend too disagree with me need a gearbox every outing and I'm not in the mood too get classed as DNF. 4 boxes so far and all with the same symptoms 3rd gear gears clean off
Almost sounds like it would be worth your time looking at geting a conversion done to an E series!
Yes same here, 3 boxes this year
Looking to get a box manufactured here in Ireland (probably 5 speed semi helical dog engagement) OR if I could find some info on the Cusco gearset I would consider it.
I've done quite a few events on my latest box without failure and I'm running very heavy gear oil which seems to help
Phil
I'm more interested in custom gearing too suit my needs the picture below is a customers evo
The aim is too keep the car stable and in boost
Look at rev drop between gear changes then add a 40ms gear change and you have a car which drives like a cvt gearbox ;)
41EEFE04-F83E-4B30-B5CC-066F480ED5E1_zps
What's your usuage?
I don't do much high speed stuff maybe 120/130 max and with the Cusco gearset (nice longer 1st) and the 3.722 final drive it would be superb
Phil
Circuit and hillclimbs
The above graph is kph equivalent to 130mph top speed
You'd need to know a top speed goal and also know what revs your in boost and you will have almost instant boost in all gear changes
My example above was too show you how much rev drop there is when going up the gears
Ah right yes
I'll get a screen shot of Cusco that I did
It'll not be a good actually cause I'm changing the smaller rolling radius of wheel/tyre
