paddy Posted August 27, 2015 Posted August 27, 2015 I need to fit a new rear engine mount, is the rear one the one I need to press out? I've done them before but many years ago, gone for the JD tuning ones, hope there not as bad as power flex Quote
JayJ Posted August 27, 2015 Posted August 27, 2015 You should press all of them, shouldn't you? Or burn or cut or hammer the hell out Quote
5e colin Posted August 27, 2015 Posted August 27, 2015 flat head screwdriver and hammer is easier to tap them out its harder pressing them because u need a perfect size to press them out the wals are very very thin !!!! Quote
Calum122 Posted August 27, 2015 Posted August 27, 2015 Colin's flat head worked a trick, the hardest part for me was getting the bastard all back together. Just tired I guess. Quote
JDMfreak Posted August 27, 2015 Posted August 27, 2015 Get a junior hacksaw put blade through mount cut the steel band around bush get a good chisel and near the edge where you cut try tap the corners up so the bush becomes loose and tap the center bushes should fall out Quote
adzy Posted August 27, 2015 Posted August 27, 2015 Get a junior hacksaw put blade through mount cut the steel band around bush get a good chisel and near the edge where you cut try tap the corners up so the bush becomes loose and tap the center bushes should fall outI did the same only made 2 cuts about 1cm apart and then chiseled out the middle piece and then the rest came out easy Quote
JDMfreak Posted August 27, 2015 Posted August 27, 2015 I did the same only made 2 cuts about 1cm apart and then chiseled out the middle piece and then the rest came out easyI just made the one cut and the steel outer sleeve moved up and I ward bush fell out then Quote
JayJ Posted August 28, 2015 Posted August 28, 2015 Please update this topic then how the JD bushes feel Quote
JDMfreak Posted August 28, 2015 Posted August 28, 2015 Please update this topic then how the JD bushes feel ive them fitted to mine at first they are very stiff everything inside shakes and rattles but as you drive for a while they start to fell much better and you get used to them but I will say this when there fitted you will never have to look at the engine bushes again Quote
5e colin Posted August 28, 2015 Posted August 28, 2015 Please update this topic then how the JD bushes feel bit better then the yellow 1s Quote
JayJ Posted August 28, 2015 Posted August 28, 2015 ive them fitted to mine at first they are very stiff everything inside shakes and rattles but as you drive for a while they start to fell much better and you get used to them but I will say this when there fitted you will never have to look at the engine bushes again bit better then the yellow 1s Thanks guys, is it too much for daily? Maybe going to change the rear gbox only if it makes any difference. Quote
5e colin Posted August 28, 2015 Posted August 28, 2015 most vibes comes out timiing belt side mount jayj so will lower vibes if stock mount is there i prefer them in a 50A TO lower vibes more Quote
JDMfreak Posted August 28, 2015 Posted August 28, 2015 ive all 3 done and they are very solid but I will be swapping out my drivers side and gear box one for standard mounts in the future my cars a daily and I find them ok just first thing in morning warming car up sitting in the car rattles my head haha Quote
