dangeestarlet Posted August 27, 2015 Share Posted August 27, 2015 If all goes well should have a auto Glanza tommorow and will want to convert it to manual, I have a n/a manual as a daily so will be taking box and parts off there , what is needed and how long does it take , any help would be great as I have searched and couldn't get a definitive answer and something about bridging to start? Quote Link to post Share on other sites
JDMfreak Posted August 27, 2015 Share Posted August 27, 2015 Yeah something to do with break pedal I did here about that before when converting from auto to manual think its something to do with ecu pins Basically got all the manual stuff gearbox cables slave cylinder on bulk head and gear box You will need to drain the bottom of rad as the auto box uses the rad to cool the auto fluid AFAIK Quote Link to post Share on other sites
lukEp Posted August 27, 2015 Share Posted August 27, 2015 (edited) You need to drill the bulk head to be able to fit the clutch master cylinder. Gear change cables and shifter, Flywheel (turbo has bigger clutch fitted so is different to the N/A)All the manual Bellhousing bolts, slave cylinder and line, manual brake pedal and clutch pedal, you'll need to modify the ignition barrel so you can take the key out and you'll need to bridge out the two big pins in the plug that was plugged into the auto gearbox so it starts when you turn the key. You also may want to change the clocks and ECU but not a necessity. If you change the ECU to a manual one be aware that the 4 pin TB will loose a 5v feed from the ecu as the manuals only have 3 pin TB's, it will still work run and drive but it hinders performance when upping the boost.The rear gearbox mount is also slightly bigger, again will fit and work but if you want to poly bush the engine mounts get the auto one or change out the rear gearbox mount to manual. Edited August 27, 2015 by lukEp Quote Link to post Share on other sites
Whitenoize Posted August 27, 2015 Share Posted August 27, 2015 Autos are actually fun dude I've just got one after having 8 manuals over the years it's pretty cool for a daily if your going for big power convert it if its just to cut about in as a daily driver give the auto a try Quote Link to post Share on other sites
Whitenoize Posted August 27, 2015 Share Posted August 27, 2015 As you can see from above it quite a big job to convert better off just to buy a manual autos are good value if you plan on keeping them auto but by the time you convert one you could have bought a decent manual Quote Link to post Share on other sites
dangeestarlet Posted August 28, 2015 Author Share Posted August 28, 2015 If I have it today I will see how it goes being an auto , don't autos drink the fuel? Any difference in quickness from a manual to Glanza Quote Link to post Share on other sites
Whitenoize Posted August 28, 2015 Share Posted August 28, 2015 Mine is fine on fuel I've a ct12 front mount exhaust etc quick little car and the gearbox is smooth give it a try see what you think but by the time you convert one you could prob have bought a manual Quote Link to post Share on other sites
Dale SR Posted August 28, 2015 Share Posted August 28, 2015 I have an automatic GT first auto I had driven and I love it. Quote Link to post Share on other sites
mart1 Posted August 28, 2015 Share Posted August 28, 2015 Love my auto v on my second :-) Quote Link to post Share on other sites
Hdot Posted September 27, 2015 Share Posted September 27, 2015 Does anyone have more info on exactly which two wires need bridging and how to modify the ignition barrel? I've got all the other parts and am half way through my conversion. Thanks Quote Link to post Share on other sites
lukEp Posted September 27, 2015 Share Posted September 27, 2015 (edited) The only two big pins in the engine bay auto box connection. I just centre punched the metal around the sliding lock to secure it in place. Edited September 27, 2015 by lukEp Quote Link to post Share on other sites
Hdot Posted September 27, 2015 Share Posted September 27, 2015 Alright lukEp il have a look when I'm next up the garage, did u keep the auto ecu with yours? I'm still unsure if I should get a manual ecu I'm also running an emanage piggyback currently so...... Quote Link to post Share on other sites
lukEp Posted September 27, 2015 Share Posted September 27, 2015 Auto has a different TPS so keep the AT ECU. If you put the MT Ecu on you will have a 5v missing off the TBS. Quote Link to post Share on other sites
Hdot Posted September 28, 2015 Share Posted September 28, 2015 Il be keeping the auto ecu then, just checked the connectors and that's all good so thanks for that info mate. When you swapped the fly wheels over is the spacer needed behind the manual one or do you do away with that ? Quote Link to post Share on other sites
JDMfreak Posted September 28, 2015 Share Posted September 28, 2015 use a turbo spacer not the automatic one Quote Link to post Share on other sites
Hdot Posted September 28, 2015 Share Posted September 28, 2015 Oh right cheers mate, il find someone breaking to pick one up Quote Link to post Share on other sites
