Ive had a driftworks one for a while and its mint. absolutely 0 play!
Same here, using the driftworks snap off hub and has 0 play like you say :)
One question, how did you get your horn to work? I have a Nardi attached to mine but the horn button is so tight?
It is a legit Nardi got it off driftworks
Edited by nikhilkamdar12
Driftworks here too, had them on the last two track cars I've owned and they're great!
I remember the horn button being a tight fit with my Nardi wheel too, they do fit, just need to persuade them home.
Yep, ive got my Tom's wheel and the horn works. Needed some general persuasion and bending of the little tabs to make it all fit and then had to use a 4mm or so socket to adjust the tightness of the two prongs so they stuck out enough. was a bit fiddly, but perfectly do-able
Cheers bro, i'll give it a go in that case.
