Clutch Slave Cylinder
Hi All,
Looking at a new clutch slave cylinder... You can get OEM spec part for £15 or a genuine part at £85...
Obviously a big difference in cost, can anyone vouch for the OEM spec?
I know a lot of things are best kept genuine, but that is a big difference if it will function just as well.
Cheers!
New cheapo one will do the trick.
And a new oem one is just rape from Toyota.
Sure i have seen uprated slave cylinder in the Hyper Revs book, wonder if there are any still about..
is the up rated version just a celica st205 slave?
You can still get the Route 6 uprated slaves
http://www.rhdjapan.com/route-6-super-clutch-release-slave-cylinder-st185-celica-ep82-ep91-starlet.html
^^ arent they super expensive??
Does the celica gt4 slave cylinder not fit?
£133 for the part, + shipping, + import tax etc. I don't even know what supposed to be different about them lol. I'm assuming the rod is longer as some aftermarket clutches require the use of a longer slave rod.
According the RHD, I'd be guessing and saying that ST185 will fit, not sure about the ST205.
