  • Replies 82
  • Created
  • Last Reply
Top Posters In This Topic
Did you lubricant all the bearings big and main when first fitted mate? This is a big shame but hold your head up high and don't give up :-)
Whip crank out, take it a machine shop and get it measured, polished or reground and polished if it's out of tolerance. Genuine Toyota bearings and some engine assembly lube.
Exactly what I did with the advance engine (after it melted the Pistons courtesy of TD)
Done 40000 mile in it since the overhaul and it's sweet as a nut. Ended up with 0.25 oversize big ends. Mains and thrusts were fine.
Yeh everything lubed and torqued up.
so looks like engine out job then... nightmare
i think the damage was done the 1st time when you over tightened her with the caps wrong way round when the crank was really hard to move
well you can drop the crank out you just need to pull box out or if ya really want pull engine out and pull the crank out either way its a set back but any crank you get have it checked first
right so ive had the crank out and had it looked over by a local engineer and he does not think there is any damage to the crank.
we measured the journals with a micrometer and the results were:
big 1 - 39.95
big 2 - 39.97
big 3 - 39.97
big 4 - 39.94
mains - all 46.99
main 1
main 2
main 3
main 4
main 5
this is the condition of the no.1 big journal in question from the above videos:
under engine shots:
sorry about the picture heaviness :)
so what do we think now? crank polish and a new set of genuine bearings and thrust washers all round?
looks like your using the wrong micrometer
i want to see 0.000
check the crank lobes urselve with your micrometer 0.000 1 not 0.00 micro there to ruff
that loube looks ruff to me mate try polishing it up before you measure it
about the bearings use thes for standard size
same but cheaper then mr toyo
http://www.ebay.co.uk/itm/JDM-TAIHO-MAIN-CON-ROD-ENGINE-BEARING-SET-STARLET-GT-TURBO-EP82-EP91-4E-FTE-STD-/301458536571?hash=item463054387b:g:JGwAAOSwnDxUkG9B
if it needs a grind it will be main dealer and 20e per chel 2 on a conrod so 40euros plus vat ontop so you get an idea of pricing 200/220euros
Ok I see where this is going now Colin is absolutely right what his saying (remember the shit I went through mate with this) when you ring up toyota they will ask you was size bearings you need, I actually have a micrometer in 000.0 cost me 50 quid aswell as the engineer I took my crank too decided to measure it in 000 not 000.0 dumbass and turned around and said we don't do 000.0 here and measured the crank to 40mm on each journal instead of the actual size it should of been in thousands of an inch, where are you located mate and don't worry it's a lot to take in at the moment but step by step we can help (especially Colin, that bloke eats, sleeps and shits these engines I swear it haha)
A lot of info I read mate when building mine, what a nightmare though, only thing I can think of here when reading about his bottom end build wrong size bearings I never did like the acl route but that's just my opinion
