as title. getting some horrific brake fade on my V. normally after 3 consecutive hard ish pushes on the pedal during back road driving.
whats the best way to get rid of this? vented discs and up rated pads? currently on OEM everything brake wise.
cheers in advance
Edited by Kazi
Drilled and grooved disk will help out with your brake fade also some better pads such as brembo or yellow stuff pad should do the trick.
Make sure you have the correct levels of brake fluid in the car and there is no leaks.
This happened on my old car and i simply bled the brakes and replaced with a premium brake fluid and it worked a treat.
Matt
all the levels are good with no leaks.
will get some new stoppers ordered over winter and get them on. thought it would be something simple like that.
cheers
Once you boil brake fluid it lowers the boiling point so make sure you get fresh fluid with that order.
I would personally look at the celica setup, can work out cheaper than stock and is so much better.
Which Celica set up we talking?
The twin pots from the ss3/GT or the 4 pots from the gt4? Luckily I have both. I'm guessing the 2 pots as the 4 would be a pain in the arse for wheel fitment.
The 2 pots a straight fit or any fabrication needed?
Ahh. Haven't come across a 185 with single pots. So is it the 185 single pots most people go for then? What's the fitting like on them?
Wouldn't bother with drilled and grooved disks, basically just for looks. Wms 110% are probably the best bet for disks
Edited by Ollieh17
