glanza ep91 23 Posted November 7, 2015 Posted November 7, 2015 Im wondering can i tidy my loom while its in the car all im looking to get rid of is,the aircon and the oem boost controller plugs and wiring? Quote
JDMfreak Posted November 7, 2015 Posted November 7, 2015 you can yeah I tidied mine with some felt tape turned out well and made look a lot cleaner Quote
Stu Posted November 8, 2015 Posted November 8, 2015 It depends on how hard core you want to go, but replacing the insulation with new wide PVC tape is a good start. All the custom looms I make these days I use braided covering rather than split conduit. Takes longer to do but the result is tidy. More photos on the old FB page if your interested. Quote
glanza ep91 23 Posted November 8, 2015 Author Posted November 8, 2015 Thanks lads all im looking to do is nothing major i just want to remove is all the oem boost controller wiring and the all the aircon wiring Quote
daniel_g Posted November 8, 2015 Posted November 8, 2015 If you rotate your injectors 180° you can take off the plastcic cover and tuck it all down near the inlet runners. Looks a bit neater. Quote
glanza ep91 23 Posted November 8, 2015 Author Posted November 8, 2015 Thanks but i was really just looking for info on tidying and removing the aircon and boost controller wiring Quote
RobSR Posted November 10, 2015 Posted November 10, 2015 Just chop it out and trace the wires back to the fusebox and remove from there too. Quote
glanzadude Posted November 10, 2015 Posted November 10, 2015 It depends on how hard core you want to go, but replacing the insulation with new wide PVC tape is a good start. All the custom looms I make these days I use braided covering rather than split conduit. Takes longer to do but the result is tidy. More photos on the old FB page if your interested.What's your Facebook account mate? Quote
Stu Posted November 11, 2015 Posted November 11, 2015 There is a link to it in my signature below Quote
glanza ep91 23 Posted November 11, 2015 Author Posted November 11, 2015 Just chop it out and trace the wires back to the fusebox and remove from there too.thanks rob ill do that, dumb question but how do u remove the wires from the fuse box thanks. Quote
Stu Posted November 11, 2015 Posted November 11, 2015 The ends of the wires have terminals on them and these can be removed from the plug. Easiest way is to use a pick and lift the keeper tab up and you should be able to pull the pin out. Quote
