As titled, spent the majority of the weekend fitting a new head gasket, get it all fired up and within minutes the water has turned into a oily mess and there's mayo on the underside of the oil cap..
I've checked and double checked the vacuum / coolant lines on the throttle body so I'm pretty sure it's not them, if someone can confirm them for me that would be great..
So If you stand on the passenger side of the car looking at the throttle body:
- Far left is water - To thermostat
- Next one along is water - To water pump pipe
- The bent one is vacuum
- The one behind that is vacuum
Cheers
Edited by TimD
This is how the head gasket has been fitted, thought i'd checked on here this is the correct way? Feel free to correct my dumb ass if it's not.
Blocked cleaned up nice
Friend of mine thinks I was too hasty getting it up and running and should have flushed everything out, will do that tomorrow and try agin.
I would be interested to know the result of this kind of baffling me now everything looks right, inlet pipes all sweet what else could it be
Correct torque procedure for the headbolts?
Head skimmed?
No hairline cracks in the block etc?
Or yeah maybe just do another oil flush and see how you get on :)
It's been fitted with ARP's, so 20, 40 60 lbft, head was pressure checked and skimmed 8thou.
Going to flush both coolant and oil and see where that leaves me, if that doesn't solve it, head off again to figure this out.
I may have spotted the problem. Where the oil gallery is from the block to the head it's not a joined. The oil gallery uses a head bolt to feed oil to the head if I remember correctly. On the standard head gaskets they are a tear drop shape (bottom left hand corner of the block on your pic) and your new head gasket does not have anywhere for the oil to go? Easiest way out? The coolant jacket.
Every Athena/JE gasket I've seen has the same layout so I'm not sure it's what is causing the problem, but you never know.
Is this new oil and coolant that's mixed?
I think I've been daft by not draining the oil and flusing the cooling system before starting it up.
Tomorrow I'm going to flush as well as possible the coolant system, and also drop the oil and replace with new stuff and see if there is any change.
Try new oils etc may need changing a few times just to make sure it's clean
There are no visible signs of an external leak, well not that I can see and having read that before firing it up that was on my list of things to check.
Heading over to work on the car in about 10 minutes
It's running.
Flushed coolant through, changed oil and it seems to be all clear. It seems to be running ok, had it up and down the little industrial estate road and it drove ok.
Hopefully going to get it in for a sniff test and have the ignition timing checked in the next couple of days!
