You can use the trigger wheels inside the dizzy but get rid of the cap/rotor etc and make a blanking plate if you wanted - have done this multiple times with aftermarket ecus and sequential or wasted spark coil setups.
  • 4 weeks later...
Have run wasted spark with high boost on many setups, but you are right about running it with big overlap cams. The second "wasted" pulse can cause a few issues.
  • 2 weeks later...
What the best coilpacks to use k20 type r ones? And what will this setup work with just standalone or emu? And what price you looking at to get this all wired in?
I have seen people use the K20 coils but I tend to use the 2zzge units. Coil on plug won't work with the stock ecu, your best bet is stand alone.
