Knock sensor wiring
I've done abit of reading regarding the knock sensor wiring and have seen a lot of responses regarding insulated wire/shielded wire etc. I've been getting my EML on, I've checked the codes and its 52. I want to re-wire the insulated/shielded part!
Where can I get it from? Any ideas?
Thanks in advance!
I'd take it to someone mate! I had that on my old gt I tried and tried to re wire it but nothing worked ! Got to the point where I couldn't be arsed with the car and stupidly parted the car out!
If I had that issue again is 100% take it to a garage who hs the experiance
I'm a mechanic myself mate so am confident in doing the work myself, I just need to source some of the wire.
At the end of the day it's either going to be 1, 2 or all 3 of these things.. Knock sensor, wiring or ecu! I'll start with the easy bit replace the insulated part of the loom, if not that then try source a second hand ep91 4efte ecu then new knock sensor << In that order, I know the sensors are around £100+. Start cheap! Worst case scenario it's the sensor and it will cost me £100+
  On 1/17/2016 at 12:54 AM, patman said:
Hello mate I take it you have found the break in the wiring?
No I haven't found anything yet, to be honest I've not even looked at the car yet. I've done a diagnostic check that's all! I get 52. Done a small bit of research and found a lot of people have had issues with the wiring so I was going to start there! :)
I've had a look at the sensor today and stripped it back to the fuel rail and can't see any issues at all with the wiring!
Where abouts is the shield earthed?
Does it earth through the ECU?
Where would I replace the wire from? At the fuel rail?
I am thinking its wiring related as since touching the wire today the engine light comes on every time I go over 3k rpm! I really want to get to the bottom of this problem as when the engine light is on the car pops and bangs a lot more!
PLEASE HELP lol!
PLEASE HELP lol!
from ecu plug mate depin the pin on the plug and run the whole wire to the knock sensor
if it works then run it tru the firewall and tape it up on the loom dont be butchering your current loom till your certain of it
Thank you Colin,
When I rewire it, do I need to leave abit of unsheilded wire before the Ecu and the same at the knock sensor end? Is there really any need to de-pin, could I just snip and use a heat shrink each end to rejoin? Or would this put to much resistance in the wire?
Thanks again!!
The shielding at the ecu end doesn't start for 100mm or so, knock sensor end its good practice to run it as close to the sensor as possible.
Remember the knock sensor shield must only be connected to the sensor ground earth pin on the ecu (E21 from memory) and not connected at the sensor end. The ecu monitors the electrical inductance compared to the normal engine ground and filters that out. Also the shielding for the knock sensor is also connected to the shielding for the oxygen sensor so make sure that shield isnt touching earth at the sensor end too.
The pin inside the knock sensor plug also can cause a bad connection - oil and shit can build up on it. Its the first thing I look at when fault finding knock sensor issues for customers. Clean and tighten the pin, check the base timing is set right, then if its not that look at the wiring then a sensor. About 60% of the time is the plug or wiring, and about 30% of the time its the sensor, and 10% its actually knock caused by timing/low octane fuel.
