4EFEJay Posted January 20, 2016 Share Posted January 20, 2016 Just bought a OMP Steering wheel and removable boss kit. Is there anything I need to worry about regarding the airbag? Can I just remove the old steering wheel, ditch the airbag and be done with it? Or will I be plagued with awful airbag lights and the such? How do people fit aftermarket steering wheels. Sorry if this has been covered just couldn't find anything to obvious about the air bag lights? Thanks Jay Quote Link to post Share on other sites
ChrisssAhhh Posted January 21, 2016 Share Posted January 21, 2016 Just remove the bulb for the airbag light and you'll be fine Quote Link to post Share on other sites
Johnboy GT Posted January 21, 2016 Share Posted January 21, 2016 There's a resistor you can put in to keep the airbag light off after start up. Think it was Socks mate that was selling them but I can't remember John Quote Link to post Share on other sites
Westley Posted January 21, 2016 Share Posted January 21, 2016 You can buy a resistor from demon tweaks too, I bought mine from then only cost about £5 and just stick it in and the light naturally goes off as it would when you had the original wheel in Quote Link to post Share on other sites
Cammy R Posted January 21, 2016 Share Posted January 21, 2016 (edited) Just remove the bulb for the airbag light and you'll be fine the garage i work at has failed a MOT because of bulbs missing, so probably not the best idea Edited January 21, 2016 by Cammy R Quote Link to post Share on other sites
4EFEJay Posted January 21, 2016 Author Share Posted January 21, 2016 Sounds like the resistor is the best bet! Will get over to daemon tweaks. Thanks. I think for MOT the test includes seeing the airbag light come on on ignition. So if the bulb isn't there I guess it can't pass this bit? Quote Link to post Share on other sites
EP70-PT Posted January 22, 2016 Share Posted January 22, 2016 (edited) No, don't remove the bulb, they'll notice, already tried that x) Still passed though, damn car was faulty (not a starlet) Edited January 22, 2016 by EP70-PT Quote Link to post Share on other sites
ChrisssAhhh Posted January 22, 2016 Share Posted January 22, 2016 (edited) the garage i work at has failed a MOT because of bulbs missing, so probably not the best ideaWell over here if there's a non airbag wheel in the car and there's no airbag light on the dash it's grandThere hardly gona take out your cluster anyway Edited January 22, 2016 by ChrisssAhhh Quote Link to post Share on other sites
4EFEJay Posted January 23, 2016 Author Share Posted January 23, 2016 I have bought the airbag delete resister kit for £9 from daemon tweaks. All arrived so will be fitting today Hopefully no major problems! Quote Link to post Share on other sites
EP70-PT Posted January 23, 2016 Share Posted January 23, 2016 You don't need to pay that much... x) get some pics up Quote Link to post Share on other sites
Westley Posted January 23, 2016 Share Posted January 23, 2016 I swear mine was only like £4.50! And if it's the same as mine it has two thin metal prongs on both wires which you simply plug into the existing airbag plug and boom is world as normal and makes it think the airbag is there as all it does is loop back on itself Quote Link to post Share on other sites
EP70-PT Posted January 23, 2016 Share Posted January 23, 2016 I'll just cut the plug from the airbags, solder a resistor and boom done, free Quote Link to post Share on other sites
4EFEJay Posted January 23, 2016 Author Share Posted January 23, 2016 All fitted Wasn't too bad! Quick release fitted too. Will get some pics up on my progress thread soon as I get on my laptop.Airbag resistor was only £4.50 my bad! Quote Link to post Share on other sites
EP70-PT Posted January 23, 2016 Share Posted January 23, 2016 Could you PM me with détails mate? And what boss dix you get? Quote Link to post Share on other sites
akyakapotter Posted January 23, 2016 Share Posted January 23, 2016 (edited) 3.1ohm resistor I used for my airbag light had to use 2 as I took both airbags out. Edited January 23, 2016 by akyakapotter Quote Link to post Share on other sites
4EFEJay Posted January 23, 2016 Author Share Posted January 23, 2016 Just updated my progress thread with the wheel fitting:http://www.ukstarletowners.com/topic/98169-4efejays-ep91-sprint-project/page-2 Could you PM me with détails mate? And what boss dix you get?The airbag canceller I bought:http://www.demon-tweeks.co.uk/performance/bosses-fitting-kits/simoni-racing-airbag-warning-canceller-kit and you need an OT-48 BossGot mine from Amazon:http://www.amazon.co.uk/gp/product/B00DUXYTF6?psc=1&redirect=true&ref_=od_aui_detailpages00 All fitted and works great! I didn't use the horn wire as i've got a removable hub for the steering wheel so will be wireing the horn up to a button on the dash. Quote Link to post Share on other sites
FMuscle Posted January 24, 2016 Share Posted January 24, 2016 I had the horn working when I had my removable steering. The spring provided requires modification, but it's really easy to do. I guess every boss is different in a way, but should be easy enough. Do you have any pictures of the boss? Quote Link to post Share on other sites
Whitenoize Posted January 24, 2016 Share Posted January 24, 2016 the garage i work at has failed a MOT because of bulbs missing, so probably not the best idea what did your garage take apart the dash on an mot to check if the bulb was in I've done it for years and never had an issue? Quote Link to post Share on other sites
4EFEJay Posted January 24, 2016 Author Share Posted January 24, 2016 what did your garage take apart the dash on an mot to check if the bulb was in I've done it for years and never had an issue?Part of the new mot guide lines are that the testers have to see the air bag light turn on with initial ignition then watch it go out. If the light never comes on, or doesn't go off. Then it's a fail.But this is subject to testers knowing the latest rules. Ohh and sticking to them. Quote Link to post Share on other sites
Cammy R Posted January 26, 2016 Share Posted January 26, 2016 what did your garage take apart the dash on an mot to check if the bulb was in I've done it for years and never had an issue? Nope just put on the ignition light comes on, light not come on=fail Quote Link to post Share on other sites
FMuscle Posted January 26, 2016 Share Posted January 26, 2016 I'm sure you can find a delay timer on eBay and have a dummy light on for a few seconds when ignition is switched on... Quote Link to post Share on other sites
4EFEJay Posted January 27, 2016 Author Share Posted January 27, 2016 I'm sure you can find a delay timer on eBay and have a dummy light on for a few seconds when ignition is switched on... Surley that's all a lot more hard work than just getting a £5 air bag canceler resister. Which i've fitted and works perfect. Quote Link to post Share on other sites
Jakemb96 Posted February 10, 2016 Share Posted February 10, 2016 Does that boss fit all OMP wheels, like the deep dish one? Quote Link to post Share on other sites
