chrome Posted January 31, 2016 Posted January 31, 2016 Hi hope someone help please. When I open the door the interior light no longer works. Is there a fuse of relay I can check. Thanks Quote
Starlet__SR Posted January 31, 2016 Posted January 31, 2016 Check the door switches too. Sometimes these can fail and are often overlooked.Day Quote
chrome Posted January 31, 2016 Author Posted January 31, 2016 Bulbs works on the switch in the light, none of the doors put the light on though.which makes me think a main component.. Quote
patman Posted January 31, 2016 Posted January 31, 2016 Mine hasn't worked for ages now, just lefted it like this and use phone torch, bulbs fine in it, thought the door switches were fine as still get the red icon on speedo cluster so would be interested aswell what's going on Quote
chrome Posted January 31, 2016 Author Posted January 31, 2016 Any one have a circuit diagram or know which fuse to look for. Quote
carson230 Posted January 31, 2016 Posted January 31, 2016 Mine was the same, door switches were faulty and connection was corrode on the bulb holder/switch for the doors Quote
Pete_A Posted January 31, 2016 Posted January 31, 2016 Mine does the same, but it occasionally works if i whack the dash just above the heater position knob, Quote
chrome Posted February 1, 2016 Author Posted February 1, 2016 I would expect one of the doors to put the light on if it were a dodgy switch? There's no corrosion in the light itself Quote
funny onion Posted February 1, 2016 Posted February 1, 2016 Both my GT's are like this. it's the door switches on both of mine. Quote
FMuscle Posted February 1, 2016 Posted February 1, 2016 I would expect one of the doors to put the light on if it were a dodgy switch? There's no corrosion in the light itself Not if you didn't notice when the first one failed, and now the second one just went... Take one of the switches off, and put a jumper lead between the wire and a good earth/ground. that will tell you if the switch is faulty Quote
carson230 Posted February 1, 2016 Posted February 1, 2016 Its hard to see the corrosion on the actual light unit as its where the two prices of metal are riveted together Quote
Bean Posted February 2, 2016 Posted February 2, 2016 Clean both door switches and check the contacts in the light. I resoldered mine and it worked again but not for long so I bought a new one from Toyota. Quote
glanzadude Posted February 3, 2016 Posted February 3, 2016 I just got two new door switches and bulb holder from toyota works fine now Quote
chrome Posted February 19, 2016 Author Posted February 19, 2016 Am I being thick but I have an interior light in the middle of the roof which works when I open the door but the front one which has the sun roof switch in does not. Is it supposed to? It only comes on when I flick the switch. Quote
