Interior light not working when door opens
Mine hasn't worked for ages now, just lefted it like this and use phone torch, bulbs fine in it, thought the door switches were fine as still get the red icon on speedo cluster so would be interested aswell what's going on
  On 2/1/2016 at 7:24 AM, chrome said:
I would expect one of the doors to put the light on if it were a dodgy switch? There's no corrosion in the light itself
Not if you didn't notice when the first one failed, and now the second one just went... Take one of the switches off, and put a jumper lead between the wire and a good earth/ground. that will tell you if the switch is faulty
  • 3 weeks later...
Am I being thick but I have an interior light in the middle of the roof which works when I open the door but the front one which has the sun roof switch in does not. Is it supposed to? It only comes on when I flick the switch.
