Help! Oil seems to not collect in my catch can??
Fitted a catch can and race spec rocker a while back on the v and rather than collect oil (is some in there) it seems to just spray it out of the breather on the side and into my bay anyway?
Think valve stems are gone as I've got oil from blow off valve and had a small boost leak on the back of my gauge in the car and it filled the car with the smell of burnt oil. Any ideas greatly appreciated
an extra breather coulld probly cure your isseu , as now al the flow is being forced to your 1 small vent hole so airflow will be fast in there being sucked/forced out
if there was more venting the oil will have time to drop before it reaches the holes as the flow will be les
thats just my 2c flyn
That makes sense to me Colin cheers. Do you think a bigger filter maybe?
The filters hidden in both pics stu, it faces towards the fire wall but has been pissing oil out only noticed as I had to pull some cable in that area :(
