Flynn Posted February 9, 2016 Share Posted February 9, 2016 Fitted a catch can and race spec rocker a while back on the v and rather than collect oil (is some in there) it seems to just spray it out of the breather on the side and into my bay anyway? Think valve stems are gone as I've got oil from blow off valve and had a small boost leak on the back of my gauge in the car and it filled the car with the smell of burnt oil. Any ideas greatly appreciated Quote Link to post Share on other sites
SKINY Posted February 9, 2016 Share Posted February 9, 2016 any pictures of the set-up ? Quote Link to post Share on other sites
Flynn Posted February 9, 2016 Author Share Posted February 9, 2016 (edited) Not the best picture.......breathers on the side facing the firewall, I've got a small k&n filter on there at the moment. Edited February 9, 2016 by Flynn Quote Link to post Share on other sites
5e colin Posted February 9, 2016 Share Posted February 9, 2016 to be anywhere near good it should have 2 or 1 big breather the can is probly not baffled Quote Link to post Share on other sites
Flynn Posted February 9, 2016 Author Share Posted February 9, 2016 It's an RJ catch can but one of the early ones.only has the one breather, would that cause the issues I'm getting Colin? Quote Link to post Share on other sites
StuDoc 72 Posted February 9, 2016 Share Posted February 9, 2016 Is there a breather on the tank I cant see it? If there isnt a good breather then it wont work at all. Pressure will always escape through the easiest possible route. Quote Link to post Share on other sites
Whitenoize Posted February 9, 2016 Share Posted February 9, 2016 Rw development cans are definitely baffled I've had a few on different cars never had any problems regarding the actual can Quote Link to post Share on other sites
5e colin Posted February 9, 2016 Share Posted February 9, 2016 an extra breather coulld probly cure your isseu , as now al the flow is being forced to your 1 small vent hole so airflow will be fast in there being sucked/forced out if there was more venting the oil will have time to drop before it reaches the holes as the flow will be les thats just my 2c flyn Quote Link to post Share on other sites
Flynn Posted February 9, 2016 Author Share Posted February 9, 2016 That makes sense to me Colin cheers. Do you think a bigger filter maybe?The filters hidden in both pics stu, it faces towards the fire wall but has been pissing oil out only noticed as I had to pull some cable in that area Quote Link to post Share on other sites
akyakapotter Posted February 9, 2016 Share Posted February 9, 2016 Mine done that binned off the filter altogether been fine ever since Quote Link to post Share on other sites
Flynn Posted February 9, 2016 Author Share Posted February 9, 2016 Really? So no filter at all? Does urs have the single breather too mate? Quote Link to post Share on other sites
5e colin Posted February 9, 2016 Share Posted February 9, 2016 yes bigger filter hole or 2nd filter my old can used to be 2 from rocker to the tank and 2 from the tank going to the intake between filter and turbo and NOT connected them 2 together as i see often happening Quote Link to post Share on other sites
ROTABOOST Posted February 10, 2016 Share Posted February 10, 2016 I have the same can and I have a hose straight off the breather fitting and its routed to come out just behind the subframe, no filter. I've never had an issue and I'm running 1.8bar of boost Quote Link to post Share on other sites
Flynn Posted February 10, 2016 Author Share Posted February 10, 2016 ^ that's an idea Quote Link to post Share on other sites
Gainzy Posted February 10, 2016 Share Posted February 10, 2016 I've never ran one never had any trouble I sometime's wonder if some parts just create problems Quote Link to post Share on other sites
Flynn Posted February 10, 2016 Author Share Posted February 10, 2016 Yea but they look dope 😉 Quote Link to post Share on other sites
Gainzy Posted February 10, 2016 Share Posted February 10, 2016 Yea but they look dope I agree sir would look even better if you had a short route IC pipe Quote Link to post Share on other sites
Flynn Posted February 11, 2016 Author Share Posted February 11, 2016 Haha I've got one it's just being a pain to route properly......but yeah massively let's down the bay! Quote Link to post Share on other sites
