Sparkythestarlet Posted February 21, 2016 Posted February 21, 2016 Hi guys my starlet is in need of a new rad but I was wondering what better replacements are there to replace it that's better than standard? I know Idworkz do a rad and you can put civic rads in them but I would like more info about the civic rads or any other good alternative? Cheers Ben Quote
Gainzy Posted February 21, 2016 Posted February 21, 2016 You can go for civic rad which saves alot of room and does the job, I like big thick front stock size rads you can get zep from rhd Japan or koyo tuning developments sell them, jperformance rad you can even use cheap ep91 non turbo rads to save cash there around £40. Most people go civic rad but I don't like them lol Quote
Calum122 Posted February 21, 2016 Posted February 21, 2016 Sparky has a UK spec I think? I needed a rad cheap and bought a JPerformance one. For what you pay you can't really fault them. Cheap, cheerful and looo good. They do the job well. Quote
Gainzy Posted February 21, 2016 Posted February 21, 2016 I have a spare rad if you need a quick fix works fine Quote
Arnold Posted February 22, 2016 Posted February 22, 2016 I bought a "standard" glanza radiator from the Facebook group which turned out to be a standard UK one. It's about 10cm shorter and also thinner. Not sure if it's suitable for the job! So just be wary the sizes are different Quote
Gainzy Posted February 22, 2016 Posted February 22, 2016 I bought a "standard" glanza radiator from the Facebook group which turned out to be a standard UK one. It's about 10cm shorter and also thinner. Not sure if it's suitable for the job! So just be wary the sizes are differentThis is true, it will work in fact I had less trouble when I ran one than my mate did with his civic rad. Good old facebook group again sounds like a bunch of cranks on there. Quote
daniel_g Posted February 22, 2016 Posted February 22, 2016 Hi guys my starlet is in need of a new rad but I was wondering what better replacements are there to replace it that's better than standard? I know Idworkz do a rad and you can put civic rads in them but I would like more info about the civic rads or any other good alternative? Cheers BenEbay - civic radiator, ive ran one on every starlet ive had. Had a triple core once but they are a bit overkill tbh. Then get a mount kit from JD Tuning on here, unless you like cable ties.. Quote
patman Posted February 22, 2016 Posted February 22, 2016 Just a quick question on these eBay civic rads are they dual core or just really skinny things, but do they hold temp well etc, been debating about getting one for ages and have mounts already Quote
daniel_g Posted February 22, 2016 Posted February 22, 2016 Just a quick question on these eBay civic rads are they dual core or just really skinny things, but do they hold temp well etc, been debating about getting one for ages and have mounts alreadyTheyre dual core. Fan very rarely even kicks in at all with them. Only thing i found was in the winter the heaters took an age to get warm due to how effective the radiators are. Quote
patman Posted February 22, 2016 Posted February 22, 2016 Can you use your own fan on them please Daniel, you know the fans what come with the standard rads and do you have a link please to the best but cheapest one Quote
daniel_g Posted February 22, 2016 Posted February 22, 2016 Can you use your own fan on them please Daniel, you know the fans what come with the standard rads and do you have a link please to the best but cheapest oneIve always just ran slim ebay fans, some people use the fan that sits against the aie con condenser.The ebay app wont let me link for some reason but if you literally just type in civic radiator you'll see them for about 40 quid.Some people have had issues with the bottom hose rubbing on screamer pipes, just depends which setup you have. Quote
patman Posted February 22, 2016 Posted February 22, 2016 Thankyou mate I will get one on there, also got a slim rad fan too thankyou Daniel mate much appreciated 👍🏻 Quote
Gainzy Posted February 22, 2016 Posted February 22, 2016 Blow your load on a zep haha civic wankers Quote
daniel_g Posted February 22, 2016 Posted February 22, 2016 Blow your load on a zep haha civic wankers Quote
StarletCraigy Posted May 27, 2016 Posted May 27, 2016 (edited) Re: You can even use cheap ep91 non turbo rads to save cash there around £40. Does this drop straight In? as I have inadvertently done just that and ordered a normal aspirated radiator, it's arrived and wondered whether it would fit my starly turbo or have to send it back. Edited May 27, 2016 by StarletCraigy Quote
