westie
    402
    Midlands
4186 profile views
westie's Achievements
Member (4/8)
  1. Both my current one (Ep95 Reflet X) and previous one (UK spec EP91 Sportif) didn't have factory rear speakers both both had the plug, it might be there on yours.
  2. Here's some photos of the plug that should be taped up in the loom behind the panel in the first photo. It's designed to fit into the factory rear speaker parcel shelf as in the last photo, but you'll be able to attach your own plug for aftermarket speakers. Hope that helps!
  3. I'll try and get some photos for you at the weekend mate.
  4. If you take of the plastic trim on the right hand side of the boot (as you look at it with the boot open) you should find a spare plug taped up in the wiring harness. This is for rear speakers, so no need to run a wire from the front yourself!
  5. This is fantastic, great stuff!
  6. Very easy. Just find the bolts to get the plastic trim off and the speakers are screwed / bolted to that. I think the wiring is just spade connectors, but it might be soldered.
  7. Yes, you could get one as an optional extra when new.
  8. I'd say 14", as UK spec standard 13" steel wheels don't fit over Glanza brakes.
  9. Hi Liam, it is indeed an EP91. Welcome!
  10. https://www.ebay.co.uk/itm/Toyota-starlet-remix-bumper-EP91-4efte/333317827122?hash=item4d9b4a6a32%3Ag%3AiIMAAOSwbOFdb8Ik&LH_ItemCondition=4
  11. Still after one? One on ebay. https://www.ebay.co.uk/itm/Toyota-starlet-remix-bumper-EP91-4efte/333317827122?hash=item4d9b4a6a32%3Ag%3AiIMAAOSwbOFdb8Ik&LH_ItemCondition=4
  12. Mine's just ticked over 250k km.
  13. If you can find a parcel shelf from the CD or GLS spec they've got integral speakers with the wiring that'll plug straight in to where akyakapotter says.
  14. Could be valve stem seals.
  15. Get hold of an EP85, swap the engine from a GT into it, take out the front driveshafts.
