Mxdsnny
Member-
Content Count
34 -
About Mxdsnny
Rank
Earth
1058 profile views
Nice!!!!
I had the same idea. Cheap, reliable, nippy. Good luck with your build.
Very cool little car! Hell of a build!
Watch this the other day. Very cool little car.
I got a white one
- 9 replies
- ep91
- daily build
(and 1 more)
Tagged with:
For ratoing, You know...... brraaaaap brrraaaap...... Acceleration? Motorway cruising?
Looks cool
- 9 replies
- ep91
- daily build
(and 1 more)
Tagged with:
Thanks, that’s nothing like what I imagined haha.
6 speed gear from a rolla g6. Will it fit a 4efe. Do you need a different clutch? Do they have better ratio?
6 speed on a n/a has it been done? Is it worth doing? Do you need a different clutch? Is there a code on the side of the box to tell if it’s a six speed n not a five? Help would be appreciated. Thanks Dan
I’ve taken my sump off to send off. And there a factory plate around the oil pick up. Does anyone have a picture of a sump after it’s been baffled? Just so I can picture what it looks like. Thanks Dan
I keep seeing This “Dean” coming up I’ll see if I can get in touch. Thanks for the help.
As titled is there or does any body know where I can find a kit to baffle my standard sump or a link to where I can buy one? I've tried searching for it but there a lot of old links.
Thanks for the info. Did you notice an increase in power at all? Or just throttle response?
Very impressed with your build so far. I have a few probably stupid questions. Are you running this on the standard ECU? If so how?? I have a set k2 throttle bodies sat in my garage and may ha e to ha e a go. I can see your using your standard TPS good mod. And the vacuum line are you running that to the ecu? Thanks Dan
