Hello all,
My 4efte engine In my Glanza started to make a tapping sound the other day, it has progressively for worse. Coolant and oil are fine, no loss in performance. Any advice would be much appreciated.
Cheers
Will
Share this post
Idle solenoid can cause tapping noise. You could take it out and give it a clean. there is a tutorial on here or TGTT.com somewhere.
Share this post
Even better, you can simply unplug it and see if the noise goes away. But this sounds worse, I would do a compression test
Share this post
The coolant sprayed all over the engine bay. There is coolant in the overflow bottle but none in the radiator.
Share this post
Valvetrain noise is 2 x engine revolution in frequency.
Hope this helps
Share this post
Bit  of an update, I have completed a compression test and it's all good. All pulleys are tourqued up.
Share this post
I took the rocker cover off a few weeks ago to look at the cams but I'm not 100% sure what I'm looking  for or measuring
Share this post
Sounds like the bottom end is knocking
Share this post
Update, ive checked the cam clearences and one of the cams tolerance is way to tight. could this be the issue?
Edited by William737
Share this post
Thanks for that, just wondering  why the gap would get closer between the cam and the shim?
Share this post
It gets closer the more the valve and valve seat wears.
Did you check the clearance when the engine was cold?
Share this post
On 11/28/2018 at 11:33 AM, William737 said:
So next thing to take off the Cams? Would it be likely to be a shim replacement?
You don't need to remove the cams to change the shim.
Pressure down on the edge of the bucket and remove the shim
Share this post
Okay thank you, I'm planning on taking a good luck next weekend, I've got another engine spare so it may come in handy.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
