DRiiFTiE
    1047
1 Follower
About DRiiFTiE
  • Birthday 02/16/1996
    Birmingham
7401 profile views
DRiiFTiE's Achievements
Boosting a Starlet
Boosting a Starlet (5/8)
  1. Glanza. Not getting reading from the front passenger ABS sensor. WANTED ABS SENSOR
  2. Wanted working controller kit
  3. Glanza V 1998 I think I have ABS problem, need some opinions! Undone nipples can’t get no fluid through.. The same both sides. Peddle Stays hard to press. Bypassed rubber hoses but still the same and with engine running still the same.. im thinking it’s an ABS Issue? would be much appreciated to get you’re opinions! Cheers
  4. Sorted. please delete
  5. Bought a OEM Fuel Reg & Lines. Turned up next day. Can’t get better than that. A* Seller
  6. Any ct9 manifolds laying around? Standard or aftermarket no cracks
  7. If you change the manifold I will take original off you.
  8. Ring or cracked piston
  9. I got a emanage blue £170 with map sensor and harness
  10. I’ll take it PM me please. If you can do a little less? Just found both items for £23 delivered new on eBay
  11. Still here I’ll take?
  12. any seats or even standard seats? upto 50
  13. Is that the code for Toyota? Synchro 5?
  14. If you dont mind about color.. I have a Lilac/purple sort of one, just hit 80k miles have paperwork for cambelt,water pump, clutch. has had brand new rear shocks and fronts replaced. starts and drives perfect. currently using it as a daily. £650
  15. wheres he located
