SiCaln
    11572
Everything posted by SiCaln
  1. adjusted it slightly, a mate and i are gonna do a compression test tomorrow (hope its not got bore wash) and check and adjust the timing
  2. thats just upsetting
  3. well i have changed the engine coolant sender, the spark plugs, leads, injectors, idle control valve and it still runs like shit and stalls at the slightest thing tbh its worse than before, checked turbo as well as wasnt getting above 0.2 bar and checked all ic piping too
  4. all the best with the new changes, should be good changes ahead
  5. he doesnt have one, you can pay me and i transfer it to him mine is sicaln@hotmail.com
  6. Sorry mate didnt see this, happy birthday boss
  7. gonna be awesome good on ya for being different
  8. SiCaln
    Skyline Ink
    really impressed with that i must say
  9. nope fraid not mate still no joy have changed the engine coolant sender, the spark plugs, leads, injectors, idle control valve and it still runs like shit and stalls at the slightest thing tbh its worse than before, checked turbo as well as wasnt getting above 0.2 bar and checked all ic piping too hating this car so much, plus its booked in for mapping friday the 9th terrific
  10. i havent put mine on yet either im scared to lol
  11. yea they looked at it, couldnt find anything wrong!
  12. the second one happened to me
  13. £1.26 where i am! never left tho
  14. What really? Whats with the change of heart man?
  15. Jeff is at garage today, running a bit sweeter now I have adjusted the idle and replaced the coolant temp sensor Will keep you guys updated
  16. i had these fitted to my old SR too, had the button in the dash but couldnt find the wiring anywhere to link them in so just pushed em to adjust the mirrors lol i had these fitted to my old SR too, had the button in the dash but couldnt find the wiring anywhere to link them in so just pushed em to adjust the mirrors lol
  17. welcome to the site
  18. awesome achievement well done guys
  19. happy to donate too guys
  20. haha excellent ad lol
  21. mileage sounds bout right to me broseph
  22. lol i was wondering what it was like, prob gna be on it this year sometime soon
  23. Just found this on another site, thought it may be of some use: Code | Signal Diagnosis and Common Trouble Area 1 System OK 2 MAP Sensor or Circuit 3 Ignition Signal from Amplifier 4 CTS/Circuit 6 RPM Signal or Circuit 7 Throttle Position Sensor (TPS) or Circuit 8 ATS/Circuit 9 Vehicle Speed Sensor/Circuit 10 Cranking Signal or Circuit 11 A/C Switch or Circuit 12 RPM Signal No G or NE signal present for 2 seconds during cranking Open G circuit Open, short in G or NE circuit. Distributor ECU 13 RPM signal No NE signal for 50msec at 1000rpm. Open G circuit Open, short in G or NE circuit. Distributor ECU 14 Ignition No IGF signal to ECU for 4 consecutive IGT signal during engine running Open/short in IGF/IGT signal from Igniter to ECU Igniter malfunction ECU 15 Starter Signal Circuit Coil pack wires 16 ECT Control Signal or Circuit 21 O2 sensor Open/short in heater circuit of Oxygen (O2) sensor for 0.5 seconds Amplitude of O2 sensor reduced to 0.35-0.70V continuously for more than 60 seconds O2 sensor Vacuum sensor ECU 22 Water Temperature Sensor no signal at THW Water temperature sensor ECU 24 Intake Air Temp sensor no signal at THA Intake air temp sensor ECU 25 Air/Fuel mixture Lean Oxygen (O2) sensor output in less than 0.45 volts for at least 90 seconds when O2 sensor is warmed and 1500 rpm or above. Open injector circuit Lack of fuel pressure Ignition system Vacuum sensor O2 sensor ECU 26 Oxygen (O2) Sensor Rich Signal or Circuit 27 Oxygen (O2) Sensor/Circuit 28 Oxygen (O2) Sensor/Circuit 31 Vacuum Sensor No signal at Vacuum sensor (PIM) Vacuum sensor to ECU 32 Vane Airflow Sensor or Circuit 33 ISCV (Idle speed control valve) Open or short in ISCV circuit ISCV Valve 34 Turbo Pressure Signal or Circuit 35 Turbo Pressure Signal or Circuit 41 Throttle Position Sensor (TPS) No signal for 0.5 seconds or more at ignition ON. (VTA) ECU 42 Vehicle Speed Sensor (VSS) No speed sensor signal to ECU when loaded driving condition with engine speeds 2000 to 5000 rpm. For 8 seconds or more. ECU 43 Starter No starter signal to ECU when cranking in TEST mode. Terminal STA on ECU Starter signal circuit Starter relay Ignition switch 47 Throttle Position Sensor (TPS) or Circuit 51 Switch Condition Signal displayed when A/C is on when TE1 and E1 connected in test mode A/C switch Accelerator pedal, cable ECU 52 #1 Knock Sensor No KNK1 signal to ECU Knock sensor loose Malfunctioning knock sensor 53 #2 Knock Sensor No KNK2 signal to ECU Knock sensor loose Malfunctioning Knock Sensor 54 Turbo Intercooler Signal or Circuit 55 Knock Sensor or Circuit
  24. massive transformation sir very good work
  25. welcome aboard sir, very interested in this sounds like good publicity to me
