triple j
    599
    Ireland
3108 profile views
triple j's Achievements
Boosting a Starlet
Boosting a Starlet (5/8)
  1. No bother lad, the td04 actuator pressure is .5/.6, a fpr should richen up that lean spot that stu is talking about I have seen it myself with the stock ecu, when mapping the emanage it was the spooling area that needed the most fuel added, a cheap apexi safc could be handy for u to clean the fueling up with the fpr, it could work well with your base timing knocked back a few degrees trimming the fuel back with the safc will add some timing back, would like to see what stu thinks of that combo I used it myself a few years ago so had plenty others.
  2. As stu says lad best way about it, I have a wideband and a knock detection device so I could give u a hand with the tune.
  3. Maybe .5 would be as far as i would like to go lad, its hard to no u will have a higher compression with the 5e pistons, I think an adjustable fpr and a check with a wideband .5/.6 could be safe.
  4. All sorted now, thanks lads
  5. Map sensor wanted asap.
  6. U won't need a press for them, the roller bearing will fall out and the outer casing just needs a tip out, just don't over tighten them.
  7. Bump for map sensor+02
  8. It should wire the same as 4efte really, u will need a map sensor for it, injectors, fuel pump.
  9. Also need an 02 sensor.
  10. As above lads anyone have what I need.
  11. triple j
    turbo gearbox
    I have one from a gt it just needs main bearing
  12. Bump still looking.
  13. As above lads, anything knocking about.
  14. I will take the antilift kit, can u pm me price posted to Ireland thanks
  15. Next time disconnect the waste gate, the won't have as much fun.
