MR-2 Posted May 6, 2016 Author Posted May 6, 2016 Tonight grinding and welding, so difficult place :/ I do other places later, must get fueltank on its place. Paint burned inside :/ Quote
MR-2 Posted May 7, 2016 Author Posted May 7, 2016 Primer and then some body sealant, horrible looking.Fast painting, better than nothing, not going to any car show :/ Quote
MR-2 Posted May 7, 2016 Author Posted May 7, 2016 Fuel tank on its place, finally get rid of boot boat tank. Not leaking anywhere, only 12 litres gasoline now in tank, have to test full tank and hope that flange don't leak.This free pressure line after Supra pump gave fuel on tarmac, very weird, had to add and weld some "bolt" there, few times because welding leaked. I use this later for efi engine. Now using return line for carburator. Quote
Pikey009 Posted May 7, 2016 Posted May 7, 2016 Amazing attention to detail and refurbishment mate Quote
MR-2 Posted May 7, 2016 Author Posted May 7, 2016 Tyres away and later new paint, like these light alloys, made in England, 6x14" Compomotives. Can't use later because of Levin front brakes, need 15" wheels :/ Quote
MR-2 Posted May 7, 2016 Author Posted May 7, 2016 Thanks for nice comments This nights project was diy adjustable panhard. One idiot shape EP91 panhard and needed bushing cylinders, so can order full Powerflex EP91 set to rear, EP70 is very hard car to get any bushings to rear. Little cut and paste, took few hours to do.One ready for welding, using welding heat to taking bushes easily away, thats why I lefted those.Welded bushing cyliders.Hardest part was to try weld panhard straight, have to do poor mans jig.On tractor oem lenght.5cm adjust from normal EP70 measurment, hopefully enough for lowered car. Quote
MR-2 Posted May 8, 2016 Author Posted May 8, 2016 Endin my garage this month, started to take parts from my spare Starlet, so rusty shit but can save some parts for modication and universal spareparts. Rare cars in Finland so have to save shit. Doors, fenders, glasses, wireloom, interior oarts and maybe roof with pilars. Quote
MR-2 Posted May 9, 2016 Author Posted May 9, 2016 So sad looking 1E engine, have to save engine mounts and intakemanifold and carburator. Lot of holes in firewall, for 4E-FE one big hole luckily in center of wall, same position as EE100 Corolla Big job coming to get loom out from Corolla or should I use GT loom? Quote
MR-2 Posted May 9, 2016 Author Posted May 9, 2016 I have EP82 GT ECU also, then I must change MR2 3S-GE 315cc injectors, don't have oem 295cc anymore. Thermostat housing must change from turbo, intake temperature sensor and knock sensor must add also if going GT loom. Quote
MR-2 Posted May 9, 2016 Author Posted May 9, 2016 Maybe cut this roof for molding, next winter maybe opentop roof for my gray Starlet... Quote
MR-2 Posted May 9, 2016 Author Posted May 9, 2016 This style, but not canvas roof, two separate glassfiber hardtop roof, so parts can be stored in rear boot. Rollgage also coming, so main bar is gona be center anyway... Quote
funny onion Posted May 9, 2016 Posted May 9, 2016 Awesome project love it you should be very proud of all the work that's gone into it! Just in the process of putting a 4E-FTE in my granny spec 70 haha. I'm using a GT loom though, wiring has been a pain because I've kept the standard fusebox and alternator/starter motor wiring. Quote
MR-2 Posted May 9, 2016 Author Posted May 9, 2016 Something different, not always bling bling and low budget work. Not the easiest car to find parts, even with big money Quote
MR-2 Posted May 9, 2016 Author Posted May 9, 2016 I'm using a GT loom though, wiring has been a pain because I've kept the standard fusebox and alternator/starter motor wiring. I'm gona keep oem and hide it and take all engine related away. So later can make or buy stand alone ecu and swap engines easily. Quote
Clinternational Posted May 12, 2016 Posted May 12, 2016 Nice project you got there love to read this stuff... Finding new parts aint easy i agree. Body welding . I've done it too. But now when i look at this project i've forgotten an place hahaha. I haven't removed the gasoline tank yet. So haven't weld against the tunnel place. Supra pump is kickass haha ;) good choice fits into many brackets also ep90 As for the pistons in the rear calipers, soak them in wd40 for few days or so. Disc brake has more control on high speed braking vs drum brakes.... P.S the ep7 rear axle is able to carry disc brake setup with minor adjustment. If you need ideas look at my thread perhaps it helps. Quote
MR-2 Posted May 13, 2016 Author Posted May 13, 2016 Thanks for comments Didn't find photos about your gasoline tank, but noticed that you are using also Supra pump and plastic collector inside tank.I have few rear disk and caliber setups, those have laying ten years at least and I have put WD40 many months, no effect, maybe so rusted inside :/Do you mean bearing adapters for using P8/9 brakes on P7 axle?Your own project tread was awesome Clint, thanks for reminding to read it, good tips for me Quote
Clinternational Posted May 13, 2016 Posted May 13, 2016 Yep also using jdm supra 2jz-gte pump. I've cut a hole on the same place were the bracket should be. Jep bearing adaptor. You'll be using for this mod same bearing as for the drum brake. The bigger shell needs to be hold into place because it is not big enough for the disc. Cut a piece of metal with an thickness of 1mm and same height and outer diameter as the shell. Then drop in the shell and add the spacer arround the shell. with an hamer and flat screwdriver. I've been driving arround for 3 years without any problem.. I cannot seem to edit the first page anymore to fix the broken link and pictures. crap P.S You know you'll have to turn the pistons....., the pistons are being held by a screw inside the caliper turn them against the clock Quote
MR-2 Posted May 14, 2016 Author Posted May 14, 2016 Also noticed that can't edit any post or title, so sad :/ Too late for me do bearing adapters, next coming that EP91 axle, made that because of newer bushings. Maybe do it later or using my cutted axle stubs, can do some camber same time.Have tryed also rotate pistons on rear calibers, only braketools are bending, should maybe give some heat, then seals must be renew. Or new calibers maybe if not cost miljons :/ Quote
Pikey009 Posted May 14, 2016 Posted May 14, 2016 (edited) You have to be a paid member to get your original post title changed. And you can request a user name change Edited May 14, 2016 by Pikey009 Quote
MR-2 Posted May 15, 2016 Author Posted May 15, 2016 You have to be a paid member to get your original post title changed. And you can request a user name change Okay, should paid, wasn't sure if have to living in UK or something to get or be real member Quote
MR-2 Posted May 16, 2016 Author Posted May 16, 2016 Started to make more room, tooked front lamp washer tank away, so much room for turbo and power steering pump and air condition not allowed in these old scholl cars. Quote
