EP70-PT Posted May 10, 2016 Posted May 10, 2016 So, some time ago I bought a BGA rocker cover gasket for my 4E-FE, it leaked... After that I decided to go on ebay (id-workz shop) and get the gasket from them, paid a lot more and what did I get?? Another BGA gasket just the same as the one I already have... Great! Quote
akyakapotter Posted May 10, 2016 Posted May 10, 2016 Just put a little sealant on bud will stop the leak. Quote
patman Posted May 10, 2016 Posted May 10, 2016 I presume your putting the sealant at the 4 corners of the cam cover? Just interested as changing mine in 2 weeks thanks Quote
Whitenoize Posted May 10, 2016 Posted May 10, 2016 Just get a genuine gasket lads I had the same trouble with numerous cheap gaskets replaced it with a genuine Toyota item never had a problem since Quote
Bug679 Posted May 10, 2016 Posted May 10, 2016 It was 14 euro for a genuine gasket from toyota just get the proper one and put a bit of sealer where the cams are and forget about it . job done Quote
EP70-PT Posted May 10, 2016 Author Posted May 10, 2016 I know but I don't have. alot of access to genuine where I am... And I thougt ID-WORKZ had the good stuff... If i k'ew it was BGA I wouldn't have bought it.. Quote
Bug679 Posted May 10, 2016 Posted May 10, 2016 If ya want i can get ya one and ship it to you ? obviously ill get a price on shipping first. you can pm me if your interested Quote
Bug679 Posted May 10, 2016 Posted May 10, 2016 Here's a list of some of the gaskets I bought from Toyota Quote
kbond Posted May 10, 2016 Posted May 10, 2016 (edited) Just buy Toyota, I done the same then used tuning developments for a genuine item and it hasn't leaked since Edited May 10, 2016 by kbond Quote
Uzzy@ID-Workz Posted May 10, 2016 Posted May 10, 2016 We have genuine gaskets on the shelf as well as aftermarket. They are all available on our website.We've sold dozens of these as well using them on our own cars and they've been spot on. I can recall one person having an issue and we sent a new one and he had no issues. If you're not happy with it mate you're welcome to return it. Just drop me a pm CheersUzzy Quote
EP70-PT Posted May 11, 2016 Author Posted May 11, 2016 Main reasons I bought from you was because of this:And because it leaked... Hope it won't do the same... Quote
Idrees Posted May 11, 2016 Posted May 11, 2016 As mentioned above you need to use sealant on the dome areas Quote
EP70-PT Posted May 11, 2016 Author Posted May 11, 2016 yes but look at the washers... the rubber is all britled... Quote
starletezy Posted May 11, 2016 Posted May 11, 2016 If you by an OEM gasket you wont have any issues it will seal it one time Quote
Ollieh17 Posted May 11, 2016 Posted May 11, 2016 Looks like you may have done the bolts up far too tight. Doing them up to tight can be worse for leaks than too loose Quote
EP70-PT Posted May 11, 2016 Author Posted May 11, 2016 thanks everyone for the replies will keep the new one and install it later, going to polish up the rocker cover anyway Quote
Whitenoize Posted May 11, 2016 Posted May 11, 2016 As mentioned above you need to use sealant on the dome areas you shouldn't have to use sealant on any part of the rocker on the gasket or the rubber washers Quote
EP70-PT Posted May 11, 2016 Author Posted May 11, 2016 (edited) It's on the manual, gasket maker around the cams onlyAnd there's some sealant on it already from factory if you take it out for the fist time, I had some there already Edited May 11, 2016 by EP70-PT Quote
starletezy Posted May 11, 2016 Posted May 11, 2016 Have changed my cover gasket 3 times using OEM never had to use sealant once Quote
