  • Replies 177
Just another quick question, I also have these OEM pedals. The clutch and brake were easy to install as the original rubber ones come off but the accelerator pedal wont; how did you install that one? Just drill through the rubber to mount the metal ones?
There is no rubber on the accelerator pedal. It’s just abs plastic. I just drilled it
On 5/15/2019 at 8:56 PM, batbo said:
Nice one, and it fuels it fine? That's quite interesting to know as I thought the JAM ecu was ideal for CT9 / Hybrid setups and TD04 at a push.
It fuels fine I think. It’s only on temporarily till I install a haltech
  • 1 month later...
  • 5 months later...
  • 2 months later...
On 2/29/2020 at 7:14 PM, Sam44 said:
Now we are talking. What's the estimated cost. Are you pushing rpm.
Whats the desired compression ratio and finally are you designing a piston as well.
Well these cost me a lot but they will be available for anyone on a made to order basis
in 4340, 300m and Titanium
built for 11,000rpm
cost is unknown just yet but depends on what
they are getting made from.... hp rating estimate 500hp+
Edited by ChaseWheatley
