mini valver Posted July 4, 2016 Share Posted July 4, 2016 Say you had iridium plugs and some good 8mm ht leads I heard a tale today there is a limit on the boost it can cope with Quote Link to post Share on other sites
jamesglanza Posted July 5, 2016 Share Posted July 5, 2016 (edited) I'm soon to be running around 1.5bar, have heard of people running up to near 1.8bar but how safe it is I couldn't tell you Edited July 5, 2016 by jamesglanza Quote Link to post Share on other sites
daniel_g Posted July 5, 2016 Share Posted July 5, 2016 People normally turn to COP ignition around 350 - 370 bhp area.Thats normally at the kinda boost levels you start blowing out the spark. Quote Link to post Share on other sites
gorganl2000 Posted July 5, 2016 Share Posted July 5, 2016 (edited) i've personally seen the stock ignition system handle boost up to 1.5 bar with no issues on gt28/td05 sized turbos...which as said above tend to give about 350bhp the individual components would need to be in good condition--plugs, wires, coil, distributor, igniter, coil and your plugs may need to be gapped appropriately/smaller at higher boost levels to avoid blow out others have claimed to run more than 1.5bar...the most i've heard is 2.0 bar on a gt28....but at these boost levels, you tend to have other issues to worry about such as head bolts, h/gasket, etc---IF they are stock Edited July 5, 2016 by gorganl2000 Quote Link to post Share on other sites
Phil Posted July 5, 2016 Share Posted July 5, 2016 (edited) Copper NGK (part number for fiesta rs turbo)£2eachGapped to .6If your wanting to run with the stock ignition.Phil Edited July 5, 2016 by Phil Quote Link to post Share on other sites
mini valver Posted July 6, 2016 Author Share Posted July 6, 2016 Copper NGK (part number for fiesta rs turbo)£2eachGapped to .6If your wanting to run with the stock ignition.PhilAnd you rate these Phil Eh. The heat range 7 ngk no good?? It was pushing 1.93 bar had no issue but the boost was tailing off so Av ordered a stronger wastegate spring see if that was the issue just a friend said he was surprised I had no issue that was the reason for the question thanks for reply lads Quote Link to post Share on other sites
Phil Posted July 6, 2016 Share Posted July 6, 2016 Heat range 8Though 7 if your mixing your own cooler fuel.Phil Quote Link to post Share on other sites
5e colin Posted July 6, 2016 Share Posted July 6, 2016 (edited) 1.9 bar i would be going for these in the link and gap as phill said i am at 1.1 on 7 gapped o.8 http://www.ebay.co.uk/itm/BKR8E-11-SPARK-PLUG-NGK-BKR8E-11-/271736264052?hash=item3f44be5574:g:nZMAAOSwB9xXOrxZ Edited July 6, 2016 by 5e colin Quote Link to post Share on other sites
Phil Posted July 6, 2016 Share Posted July 6, 2016 I'd go copper core - super cheap And heat range 8 by NGK£8 for a set of fourhttps://www.ebay.co.uk/itm/182053703500 Phil Quote Link to post Share on other sites
Chief Quimby Posted July 15, 2016 Share Posted July 15, 2016 I ran 2,3 bar on my 5Efte with a gt3071, stock ignition Quote Link to post Share on other sites
Gainzy Posted July 15, 2016 Share Posted July 15, 2016 I ran 2,3 bar on my 5Efte with a gt3071, stock ignitionWhat power any graphs Quote Link to post Share on other sites
Phil Posted July 15, 2016 Share Posted July 15, 2016 Build thread is on here and info over on tgtt to.Prob as handy just searching his username on herePhil Quote Link to post Share on other sites
Chief Quimby Posted July 15, 2016 Share Posted July 15, 2016 Was running 412hp at 2,1 bar with the small 0,63 exaust housing Quote Link to post Share on other sites
Chief Quimby Posted July 15, 2016 Share Posted July 15, 2016 Only have this, this was 1,35 bar with the small 0,63 housinghttp://www.bilgalleri.dk/album/storbilledevisning/45820-revnet_manifold?n=2297372 Quote Link to post Share on other sites
GP82 Posted July 15, 2016 Share Posted July 15, 2016 I have ran upto 25 psi on the stock ignition and it has been fine with iridium plugs, stock leads. As said when all the ignition parts are in good condition it will be fine. Quote Link to post Share on other sites
