I've finally installed my AEM wideband to my car and on boost, i'm getting readings as low as 10.0. That's the lowest the dial will report. I've heard 11.5 sounds about fine, but 10.0 is obviously way too rich right? She's got an E-Manage Ultimate fitted
If its in the 10's on boost there wouldn't be much power to be had as it would be on the verge of bore wash and she would be bogging down on u,what's it reading at idle.
Have standard ecu in my GT, have a sard fpr on only running 0.8 bar for now, (till got time to change things) anyway I find dropping the fpr down to around 2.2 bar, I get around 11.0/11.2 on WOT that's in 4th of course, so obviously these standard ecu's are made to run rich.
Idle is around 14, it fluctuates a little. She drinks fuel on boost so yeah it's probably just very safe! I'll go get her checked out
Was at a dyno day a year or so back and a mates n/a fezzie st was in the 10s (stock 😂), the operator reckons he'd only expect to see a car with low 10 afr's if it was a drag car or very high performance.
  • 2 weeks later...
My wideband reads 10.0 on full boost 4th gear. Mapped by TD and it's never missed a beat. On EMB that's how they set them up
There would be a major hike in power leaning out from 10afr to a still safe 11.0/11.5 on boost, u can feel the difference from the seat alone, one thing u would be sure of is not getting det with the 10.0afr bore wash.
Edited by triple j
When mine was mapped by TD it taper'd down to low 11's, every now and then i saw a high 10. They will go rich on a standard engine top end to stop them destroying themselves.
